Question about LifeGuard Aquatics Impellers & Shafts for Quiet One Pumps - 9000 Impeller
I unplugged pump to do water change when i plugged back in nothing worked
Maytag washer starts drain pump and nothing else works
best guess timer issue
timer runs all the water ins and outs and wash cycles
or depending on model electronic controller board
not sure why the machine is unplugged often
it is worth buying a one plug surge protector
hint
unplugging to fix any washing machine during a set wash cycle only interrupts the timer
spinning the timer around fast to restart an unfinishied cycle .damages the timer
Oct 11, 2016 | Maytag Washing Machines
How do I know if my water pump is broken, or just plugged?
the water pump is easy to take out and clean. you have either a little door in the front or the panel in the back. Unplug the washer, turn water supply off. remove the panel and you will see the pump. 2 hoses are clipped into the pump. remove them ( catch water with towels or a bucket ) . The pump is bolted down. just remove the bolts and check the pump for obstructions. there are a few screws on the pump, open them and you can clean the pump out more. re-assemble and re-install. Pumps are usually hard to kill. check the hoses and make sure nothing is stuck in them. plug in washer and open water supply and put on spin. if it pumps then problem solved. if the pump still doesn't work, then it might be the control panel which is very easy to replace. I've done it all and I'm no expert. good luck
Jun 30, 2014 | Samsung WF328AA Front Load Washer
The ul keeps coming whether it be one small sock or filled with bedsheets. I put a new pump on thinking the old was not pumping all the water out causing it to ul. Nothing has changed. Please advise
this is usually a main control circuit board problem...you can try and clear the board by unplugging washer and get access to board area.. unplug the touch pad and wait two minutes..now leaving touchpad off..plug washer in for tw minutes...now unplug the washer and install the touchpad and put together and plug washer back in...this should clear codes..if it works ok Great..if not, order main ccu board
Jan 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Water through the door stopped. The selector for
I have the same problem. I was thinking that the water line is frozen. I unplugged it for a couple of hours, plugged it back in and water started trickling out. I'm going to adjust the temperature in the freezer so it is not so cold. Maybe that will help too. Thats about as far as I have gone for troubleshooting so far.
Feb 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Power is on. Shows code 88 and nothing changes. I had the unit in storage for one year. I purchased new.
code 88 is telling you its ready to program hours if you have tried to set with arrows unplug unit and let it stand for ten minutes and plug back in this helps reset it
Jun 23, 2009 | Intex Automatic Salt Water System for ...
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
I need to reset duet washing machine to open the door
????? your pump just runs??? is it pumping water???if you rermove the lower aceess panel(3 screws across the bottom) youll gain acess tot eh pump clean out, perhaps its clogged , not pumping any water out
Dec 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Won't do anything
try to remove as much water as possible ..wet vac will help pull unit out remove back cover lean washer forward on left bottom is drain pump remove 3 screws holding pump and clamps holding hoses on pump..on motor side of pump are 4 screws remove them noting location and orientation of pump body clean out ..ck impeller ..round white part with fins ..if it is not broke try turning it by hand should turn but with some resistance if free wheels replace pump if you found stuff in pump reinstall and ck
Aug 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't do anything
This is another possible solution, more than likely most people will expierience clogs. I had the same problem today, upon removing the drain pump I noticed one of the dark blue wires was off of the connector that plugs into the pump, seems these are held in place by a "splice connector", and is a simple fix, after you unplug it from the drain pump take the connector and pull from the front and rear to open the splice jaws, re insert the wire and push back together. Plug it back into the pump, and that's it!
Dec 30, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
LifeGuard Aquatics Impellers & Shafts for Quiet One Pumps - 9000 Impeller Logo
120 people viewed this question
Top LifeGuard Aquatics Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a LifeGuard Aquatics Fish Expert? Answer questions, earn points and help others
