Question about Philips HR1861 700 Watts Juicer
How to take it apart for cleaning - Philips HR1861 700 Watts Juicer
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
Jun 10, 2015 | Braun MPZ-22 Juicer
How do you take it apart to clean it ?
It's really easy, you take down the metal bar and the top comes off, then you should see the orange mesh basket which is removed using your little tool - it's like a key which you turn to remove the basket - rinse under the tap - piece of cake.
Mar 15, 2010 | Jack Lalanne Power Juicer (Stainless...
HOW DO I GET MY JUICER APART TO CLEAN IT
I looked all over for the disassembly instructions for the JM300 to no avail...so I got a flathead screwdriver and decided I'd either get the darned blade out or break it for good. It took some prying but the blade popped out and it was the RIGHT way to handle it after all. Now everything is clean and ready to use again.
Sep 14, 2009 | Juicers
Cant get it apart
I bought this machine in a garage sale and i cant seem to take it apart.
Jun 20, 2009 | Jack Lalanne Power Juicer (Stainless...
How to take apart to clean?
use a large paper clip!!! I did and it worked.
A
Jun 12, 2009 | Jack Lalanne Power Juicer 250 Watts
Taking Juicer apart
http://www.myeasypics.com/is.php?i=488929&img=jack_lalanne_operating_manual__0003.jpg
Mar 26, 2009 | Jack Lalanne Power Juicer 250 Watts
How to clean blade and screen
First thing you need to do is take it apart, which can be done pretty simply until you get to the actual blade and strainer. You will need to use the crescent tool, the one with two pins. Insert it in the blade, and turn it counterclockwise while holding the filter so it doesnt turn. All the parts should come apart easily.
i find the best way to clean these parts is using a small brush, not a sponge or rag.
Mar 02, 2009 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Philips HR1861 700 Watts Juicer Logo
29 people viewed this question
Top Philips Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Philips Juicer Expert? Answer questions, earn points and help others
