Question about Meridian Two-Line Corded Business phone
Can not get a dail tone in the handset, but i get a dail tone through handsfree
I have a vtech cordless phone.I got it today the dail need help tone won't go away I can't dail out it won't go away
You have a bad handset. Depending on the model you can order a replacement on Amazon. If you bought it new ask for a replacement.
May 07, 2017 | Vtech Lands Phones
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
There is no dial tone or sound, but the calls go through
Does it work on handsfree or with the handset ? It should work for one of those. Make sure your handset isn't plugged into the headset port on the bottom of the telephone. If it's still not working, change the handset and curly cord with one from another phone to test if that's the issue. (but then the Handsfree should technically work)
May 24, 2011 | NorStar Meridian M7310 Phone
My s11 does not have a dail tone
Make sure that the S11's AC adapter is plugged in so that it has power. Check the compatibility setting on the left side of the base, the typical setting is number five, however you can try it on other settings to see which works better for you. And then you should get a dial tone when you lift the handset receiver off hook, and then you will have to hang the handset receiver up to end the call.
Good luck from Headsets Direct!
Feb 27, 2011 | Plantronics S11 Headset
Hi I am trying to get a dailing tone but nothing is happening
Firsst of all check the line to the base phone, test with a good phone for confirmation or test the voltage of the line. next clean the surfaces of the handset contacts to the base. check if the battery of the handset is good. if not replace. Next placing the phone on the base should make it detect the base. If the base and the handset does not mate, then you will not get the dial tone. this could be due to failure of the inout due to lightening/ thunderstorms, failure of the optocouplers, the dial switching ICs or the main processor. You will need to check on these electronic sections. I hope this helps. Good day
Jul 12, 2010 | Panasonic KX-TG1100 Cordless Phone
Handsfree mute always on
your phone is not dying. Once you pick up a phone press 9. This will automatically grab a line. Dial your number.
Mar 17, 2009 | Astra Meridian 9417 Corded Phone
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
Meridian Two-Line Corded Business phone Logo
14 people viewed this question
Top Meridian Lands Phones Experts
george  peters
george peters
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
