Question about Adaptec ADP660 Adp 660 Dot Matrix Printer Mfr P/N ADP660
Serial number on adp 660 dot matrix printer
Where can I find serial number
How I print a config sheet
To print the test page hold the pause button of printer and on the printer. dont leave pause button till the printing .
Sep 25, 2014 | Epson TM-U325D-940 DOT MATRIX RECEIPT &...
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
I want serial number
The serial number is the number on your unit that gives the manufacture info if you have a problem. It gives them such info as to where it was assembled, when it was assembled and the factory features installed on the unit. It is all coded for the manufacturer.
Mar 17, 2010 | Tally T2250 Matrix Printer
I'm getting yellow spots on one side of every page that I print. djmilner
these yellow dots are an hidden marking solution to identify printers by their serial number and date and hour of print. these information could be decoded from the repated matrix of yellow dots print along all the single paper...
Mar 08, 2010 | HP LaserJet 3000n Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Drivers needed for ADP 210 dot matrix printer
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
Feb 21, 2009 | Epson LX 810 Matrix Printer
Sir It to inform you that my TVS printer MSP245 Serial No.FAH2MC001356 is not printing properly.Kindly register my complaint and send Technician in the following address- M/S Mayank Enterprises, Gandhi...
Dear Mayank,
Please call 30309797 or 30301717 at Call Centre No. to get register the call. You can also put mail at support@tvs-e.in along with printer model and serial no. for registration.
Regards
TVS-E
Feb 20, 2009 | Epson LQ-2180 Dot Matrix Printer
Tvse nova 130 printer drivers needed --cannot print from vista
TYPE IN ADDRESS BAR
MANUFATURES NAME, MAKE, MOLDEL, DRIVERS
ROD
Feb 09, 2009 | Office Equipment & Supplies
Adaptec ADP660 Adp 660 Dot Matrix Printer Mfr P/N ADP660 Logo
23 people viewed this question
Top Adaptec Office Equipment & Supplies Experts
k24674
Are you an Adaptec Office Equipment and Supply Expert? Answer questions, earn points and help others
