Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • 4 more comments
  • Anonymous Nov 03, 2007
    Top draw wasn`t working eventually found the heating element fuse blown, i repaired that now the the top lid motors aren`t driving up or down.
  • dbIowa Feb 11, 2008
    I have the DD603 and my top drawer will not power on. The bottom works fine.
  • Jeff Kiddman Mar 07, 2008
    Having the same problem. The top drawer does not power up, and the bottom drawer works fine.
    Tried to pull the plug to reset the system. Did not work. Also made sure Auto Power option was "on".
  • Anonymous Nov 27, 2008
    the top drawer looks as if it will wash then stops and it says F2.what is the problem and how can i fix it..
  • sonniewater Dec 10, 2008
    Bottom works fine, top only beeps when lock is pressed It was slamed open,(its on a boat)Thanks for any help.
  • dewerner Feb 04, 2009
    My DDR603 top drawer powered off Mid Cycle. I swapped out the Control board & LCD panel from the working bottom washer & no help. The top stoll does not power on and the bottom works fine. Using a volt meter, the top control board seems to be getting 120v power. Is there some other safety shuto off part I need to check or replace?
    Problem Solver:
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Posted on Mar 30, 2010
I HAVE A DD603. Thr F1 comes on about every 2 weeks. I shut power off & let it dry & it works fine for acouple of more weeks. Any idea why this is a on going problem and how to fix it?
Posted on Nov 06, 2008
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Fill fault on top tub and bottom works fine. getting about 30 ounces of water and it takes about 3 minutes for fault code to come up
If your bottom drawer works fine then your inlet water valve below the bottom drawer is bad. Click on the link below to see how to repair this dishwasher.
Appliance Repair Video
Mar 26, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Top Drawer Beeps all the time. Will work if patient. Bottom drawer OK.
I am assuming only the bottom drawer works and not the top.
Are you able to note down which LEDS on the top drawer door inside top are on?
Sep 19, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
1,038 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
