Question about Toys
Rogator 854 problems outside boom section raises too slow.
Bought an 854 with 80 ft.boom . we added 5 ft. and now it raises too slow.
2000 Honda CRV, how to remove rear axle shaft
REMOVAL & INSTALLATION
  1. Loosen the wheel nuts.
  2. Carefully raise the locking tab of the axle spindle nut using a hammer and chisel.
  3. Loosen and remove the axle nut.
  4. Raise and safely support the vehicle.
  5. Remove the rear wheel.
  6. Remove the halfshafts from the differential. Refer to the differential removal procedure in this section for specific details.
  7. Carefully remove the halfshaft from the trailing arm assembly by tapping on it with a plastic hammer, or using a suitable drift and hammer.
To install:
    Installation is the reverse of removal taking note of the following points:
    • Install new set rings in the groove of the splined inner CV-joint shafts.
    • Top off the differential fluid as necessary.
    • Install a new spindle nut and torque to 134 ft. lbs. (181 Nm), and once tightened, stake the nut.
    • Tighten the wheel nuts to 80 ft. lbs. (108 Nm).
Dec 10, 2015 | Honda Cars & Trucks
Replace cylinder in bottom boom on hiranger bucket truck
ive heard of folks doing it without a crane but i would not try it , alignment is too critical with getting guides and stops back in and with nothing to move boom that would be too difficult
anyways: suspend boom end with double straps from crane , disconnect hydraulic/electric swivels/plugs at truck end lift end of boom slightly with boom all the way extended straight out , remove acess panel (both sides) at jct of upper/lower boom section . remove C clip one side drive out pin oppisite side (wiggle boom to clear pin) locate stops in lower section boom end unbolt , slowly pull upper boom with crane away take care of hydraulic lines and electric wires set on floor on wood cribbing , locate bottom of cylinder truck end find C clip and pin Might be behind a trim cover that might need to be remove drive out pin also remove bottom cylinder hyd hose connect crane to cylinder end move out a foot or so remove top cyliinder hydraulic hose then carefully slide out cylinider with crane , Note if your valves are not tight and new oil will leak back and cause boom base to sag when you unhook hydraulic hoses , your gonna need to block this up with wood cribbing just in case
reverse removal process to install new one , also i would not just install a new seal (you can) with out having cylinder recromed I'll bet it's rusty thats what tears the seals up
and allways replace entire oil volume in hydraulics your old seal is in old oil not good for the new one
Apr 26, 2014 | 1985 Chevrolet Chevy
Starter removal of a 1995 contour
Removal and Install procedure on 2.0L...
  1. Disconnect the negative battery cable.
  2. Remove air intake resonators.
  3. Remove starter motor upper mounting bolts.
  4. Raise and support the vehicle.
  5. Remove the nuts on the starter terminals and remove the cables from the terminals.
  6. Remove the two starter lower retaining bolts and remove the starter.
To install:
  1. Place the starter into position and tighten the 2 lower retaining bolts to 15-20 ft. lbs (20-27 Nm).
  2. Place the starter cables onto the terminals and tighten the retaining nuts to 80-124 inch lbs. (5-7 Nm).
  3. Lower the vehicle.
  4. Install and tighten the upper retaining bolt to 15-20 ft. lbs (20-27 Nm).
  5. Install the air intake resonators.
  6. Connect the negative battery cable.
Hope helps.
May 14, 2011 | Ford Contour Cars & Trucks
How many cubic yards of material are needed for the foundation of a barn 40 by 80 ft., if the foundation is 2 ft, thick and 12 ft. high?
I'm sorry to tell you but it's actually wrong..
this should be how it drawn..to solved this two volume is needed..the outside and inside volume..12_5_2012_12_36_29_am.gif
V(outside)=80(40)(12)
V(outside)=38 400 cub. ft.
V(inside)=(80-2-2)(40-2-2)(1...
V(inside)=32832 cub. ft.
V(total)=V(outside)-V(inside)...
V(total)=5568 cub. ft
convert to cub. yard=206.22 cub yd.
Jan 10, 2011 | Computers & Internet
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
How to disassemble the rear end in a 2000 gmc yukon and how to remove axles
Removal & Installation To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Loosen the lug nuts on the wheel and tire assemblies but do not remove the lug nuts
  3. Raise and support the vehicle
  4. Remove or disconnect the following:
    • Wheel and tire assemblies
    • Axle lubricant into a suitable container
    • Rear driveshaft
    • Parking brake cable
    • Brake calipers
    • Shock absorbers from the axle brackets
    • Vent hose from the rear axle vent fitting
    • Nuts and the washers from the U-bolts
    • U-bolts, spring plates and spacers from the axle assembly
  5. Lower the axle assembly from the vehicle
To Install:
  1. Place the rear axle assembly under the vehicle
  2. Align the rear axle assembly with the springs then connect the spacers, spring plates and the U-bolts to the rear axle
  3. Raise the rear axle assembly into position
  4. Install or connect the following:
    • Washers and nuts to the U-bolts; Torque to: 59 lb-ft. (80 Nm) then, Torque to: 89 lb-ft. (120 Nm)
    • Vent hose to the rear axle vent fitting
    • Shock absorbers to the rear axle
    • Brake calipers (See: Brake Caliper)
    • Parking brake cable (See: Parking Brake Cable)
    • Rear driveshaft (See: Rear Driveshaft)
  5. Fill the rear axle with lubricant
  6. Bleed the brake system (See: Brake Bleeding)
  7. Install the wheel and tire assemblies
  8. Lower the vehicle to the ground
  9. Torque lug nuts as follows:
    • Single Wheel: Torque to: 140 lb-ft. (190 Nm)
    • Dual Wheel: Torque to: 175 lb-ft. (240 Nm)
  10. Road test the vehicle to check performance
Aug 03, 2010 | 2000 GMC Yukon XL
How do I replace the alternator in a 2002 hyundai sonata GLS v6?
For 2002 Hyundai Sonata 2.7L MFI DOHC 6cyl check this procedure...
Alternator - Removal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
    Fig. Exploded view of the alternator-XG 300
  1. Before servicing the vehicle, refer to the Precautions section.
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
Hope helps (remember rated this).
Jun 25, 2010 | Hyundai Motor 2002 Sonata
How to change the fuel pump on a 2000 ford expedition
Removal:
2. Relieve the fuel pressure.
3. Raise and support the vehicle.
4. Remove the fuel tank; refer to the procedure outline in this section.
5. Remove the fuel pump retaining bolts.
6. Remove the fuel pump.
To Install:
7. Thoroughly clean the fuel pump-mounting flange.
8. Install a new gasket and place the pump into the tank.
9. Ensure that the fuel tubes face toward the fuel rail and tighten the retaining bolts to 80-107 inch lbs. (9-12 Nm).
10. Install the tank as outlined in this section.
11. Tighten the fuel tank bolts to 66-91 inch lbs. (7.6-10.4 Nm).
12. Tighten the fuel tank straps bolts to 22-30 ft. lbs. (29.7-40.7 Nm).
13. Tighten the skid plate bolts to 9.3-12.7 ft. lbs. (12.7-17.3 Nm).
14. Connect the negative battery.
Dec 20, 2009 | 2000 Ford Expedition
How to 1998 Taurus altenator R&R
please rate highly if this helps
Generator 3.0L (2V)
Removal
  1. Partially raise the vehicle on a hoist. Refer to Section 00-02 .
  2. Remove the right front wheel. Refer to Section 00-02 .
  3. Remove the lower fender splash shield retainers and position the shield out of the way.
  4. Lower the vehicle.
  5. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  6. Remove the power steering line bracket and heater hose support bracket from the generator.
  7. Remove the upper generator bolts.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Disconnect the right hand stabilizer link.
  15. Lower the subframe to provide clearance.
  16. Remove the generator.
Installation
  1. NOTE: Do not tighten the lower bolt.
    Install the generator and the lower bolt.
  1. Raise the subframe and install the subframe bolts. Tighten the bolts to 90 Nm (66 lb-ft).
  1. Connect the right hand stabilizer link and torque to 47-62 Nm (35-46 lb-ft).
  1. Remove the adjustable stand.
  1. Lower the vehicle.
  1. Install the upper generator bolts and tighten them to 25 Nm (18 lb-ft).
  1. Install the power steering line bracket and the heater hose support bracket. Tighten the nut to 20 Nm (15 lb-ft).
  1. Install the accessory drive belt. Refer to Section 03-05 .
  1. Partially raise the vehicle.
  1. Tighten the lower generator bolt to 25 Nm (18 lb-ft).
  1. Connect the generator electrical connector.
  1. Install the battery positive B + cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Install the generator splash shield.
  1. Install the fender splash shield and the retainers.
  1. Install the right front wheel.
3.0L (4V)
Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 14-01 .
  1. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
  1. Remove the power steering line bracket and heater hose support bracket from the generator.
  1. Remove the upper generator bolts.
  1. Remove the right front wheel. Refer to Section 00-02 .
  1. Remove the lower fender splash shield retainers and position the shield out of the way.
  1. Remove the generator splash shield.
  1. Raise the vehicle.
  1. Disconnect the electrical connector and remove the battery positive cable from the generator.
  1. Remove the right subframe bolts.
  1. Remove the lower generator bolt.
  1. Lower the subframe to provide clearance.
  1. Remove the generator.
Installation
  1. Install the battery positive B+ cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
  1. Connect the negative battery cable.
3.4L (4V)
Removal
  1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
  1. Remove the right side cowl vent screen. Refer to Section 01-02 .
  1. Raise the vehicle and remove right front wheel assembly. Refer to Section 00-02 .
  1. Remove right tie-rod. Refer to Section 11-02 .
  1. Remove accessory drive belt (8620) from generator. Refer to Section 03-05 .
  1. Disconnect electrical harness connector and output terminal wiring.
  1. Remove nut and position engine control sensor wiring (12A581) out of the way.
  1. Remove the two bolts and one stud bolt.
  1. Remove generator from vehcile
May 12, 2009 | 1998 Ford Taurus
1993 Mercury Grand Marquis Problem:
Well in my madness of trying to figure it out with mama wanting it fixed and fixed fast and it being Hot! outside. I set back in the cool air with drink in hand wishing she had to do it instead of me, thought about it and said Ahhhhh! Coil pack or wires. I chose "coil pack" The problem is gone, Mama is happy and the world is right once again.
Coil pack would heat up and then breakdown.
Jul 24, 2008 | 1993 Mercury Grand Marquis
Toys Logo
43 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
