Question about Home Security
Set combination on samsonite 3 number lock - Home Security
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
  • 91 Answers
SOURCE: My Samsonite suitecase is open, I forgort my lock
look behind the lock
there is a tiny part (like a stick shift) sticking out of a square about 1 cm across
move it to the diagonally opposite side
reset code
return shift to old position
For those without the little stick shift part, try this: With the case open, and the current combo in place, hold down the shackle (the little grey or black button beside the combination numbers).
While holding this shackle down, rotate the numbers to the number YOU WILL REMEMBER.
(Holding the shackle down allows the numbers to tumble without moving the divots.)
Let go of the shackle -these numbers are now associated with the divots.
Now your combination should be set to the number you wish.
Hope this helps,
Karlos
Posted on Jul 04, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
matt2414
  • 247 Answers
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Set combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
How to unlock samsonite combination lock?
1. Call Samsonite Customer Service at 1-800-262-8282. Representatives are available Monday through Friday from 10:30 a.m. to 5:30 p.m EST.
2. Press "1" and then "6" on your telephone keypad to speak with a representative to order a replacement key or padlock.
3. Pay the required fee. Samsonite will then send out the replacement key.
Aug 17, 2012 | Samsonite Tsa Acceped Padlocks Allow You...
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
HELP needed to open combinaiton lock
side latches of my samsonite brei case is open but cant get the combination lock to release
Jan 21, 2010 | Samsonite Case & Tripod Kit for Digital...
Oct 16, 2009 | Samsonite Tripod
How to set Samsonite combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Sep 26, 2009 | Kwikset Locks & Locksmithing
Samsonite attache case lock
I just used the following solution successfully...
thanx to whomever posted it.
Dear Sir/Madam:
narrow space.)
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Apr 08, 2009 | Samsonite Tripod
Forgot my 3 digit number lock on my samsonite bag
Sep 17, 2008 | Samsonite Tripod
Home Security Logo
15 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
