Question about Gaggenau Cooktops
Gaggenau part I NEED AN ADDRESS FOR PARTS IN CANADA MONTREAL QC
I have a Gaggenau cooktop, two VG223-802 and one center VR122-612, need countertop cutout dimensions for the three.
-Take measurement yourself and cut to any size you want.
It's sample
Good luck
Mai
Dec 27, 2017 | Gaggenau Cooktops
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
I need the two front knobs that come out from the front lower inside unit that are the igniter controls for tge gaggenau vg 353 112 cd. Please lead me to the part numbers and a parts supplier. Thanks brian
Here are the diagrams, parts list, and sales of the parts. Specific to Gaggenau VG353. Additional site to order parts: Essentials For Your Home website, just put in the part number from the diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232110&diagram_id=193996#d193996
Jan 16, 2011 | Gaggenau 15 in. VG 353 Gas Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau kg260 gas hob, ring not staying lit, possible thermo-couple gone, request replacement cost / parts please
Thats the Stainless Steel model KG260-234CA with SuperQuick electric and Safety Thermocouple ignition, I think they come in pairs RS and LS, for around $27.00 per Pair + tax and SH.
The best place to get them will be SEARS PARTS DIRECT on Line at: http://www.searspartsdirect.com/
Eddie Rentas
Tupper Lake NY.
Jun 25, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau VG-352-812 Cook top
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Jan 03, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau gas rings
The heat has caused it to be stiff. Just apply steady pressure and it will lift off. Gaggenau is real good about making sure that if a part is screwed down that you can find the screw.
Oct 23, 2007 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau clicking
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
Jul 27, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Cooktops Logo
62 people viewed this question
Top Gaggenau Cooktops Experts
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
