Question about Chicago Faucets Plumbing
Galileo 650 series no water
No water coming out faucet
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
I replace the O-rings and cartridge on a legend
check the diverter sleeve/collar it may be getting in the way ,and water push's it out of the way.
Mar 02, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
No water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
May 27, 2009 | Price Pfister J103-BC 100 Series Kitchen...
''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
Apr 10, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
20 people viewed this question
Top Chicago Faucets Plumbing Experts
Donni Steen
Tom Chichester
Are you a Chicago Faucets Plumbing Expert? Answer questions, earn points and help others
