Question about Universal Remote Control MRFB600MURCBL - Wall Box Dimmer Black
What Lutron RF Dimmer will match to the MX-450 URC
Lutron tech says the MRFB-600M0URC-BL is the one for 434 MGHZ. or the MRFA-600M-URC-BL for the 184 MGHZ My MX-450 URC is rated at 413 MGHZ I am also using a MRF-260 URC Base station that pairs with my MX-450 URC. I don't know if the base station is compatible with Lutron dimmer I need. Can someone give me guidance?
5 Suggested Answers
Bulldog AV
  • 52 Answers
SOURCE: My new fan with light fixture is hooked up but it
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Posted on Nov 23, 2009
SOURCE: My MX-3000 remote won't turn on. My battery had
reset by disconnecting battery
Posted on Dec 26, 2009
jhinsincity
  • 616 Answers
SOURCE: I have a direct tv
I believe DirectTV has excellent customer service reps that would be delighted to help you!
Posted on Jul 24, 2011
gopakumarg43
  • 74251 Answers
SOURCE: 4 digit code for philips dvr
0483,0829,0184,0338 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Posted on Apr 14, 2013
Require schematicwiring ofma400 and high power 2 lutron dimmer
You can access Lutron's Wiring Library here:
http://www.lutron.com/Service-Support/Technical/Pages/WiringDiagrams.aspx
I couldn't find an MA-400 or High Power 2 dimmer, so you might want to double check the model numbers and look for a match in the link above.
Jan 02, 2012 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Bought a house with lutron slide dimmer switches, but the plastic knobs are missing. I found replacements at home depot but they didnt fit. it is an older home. where can i find them
I wouldn't spend a lot of time trying to hunt it down yourself. Call the tech support number at 1-800-523-9466. First of all, they're there 24/7. If its the wrong size knob then it sounds like you just need some help matching up model numbers. If you can find the model number on the dimmer itself, that will help - but call them up and they'll probably just send you the parts you need.
Feb 18, 2011 | Lutron ELECTRONICS CO. GK-WH SLIDE DIMMER...
Lutron dimmers throught the house, lights go high brightness to low all by themselves, is this just a bad dimmer?
I have spent considerable time on the Lutron site past couple days looking at their dimmers.
Lutron has a lot of dimmer varieties. The basic breakdown is 600Watt and 1000Watt. But different dimmers control different types of lighting.
Here is the long list of Lutron dimmer manuals:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
Oct 17, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Why does the light change levels on its own?. Ijust replaced this switch 4 days ago and after awhile it started again.
Call their tech support center at 1-800-523-9466. First of all, they should be able to send you a replacement. You also may be able to talk them into a different product that doesn't have the same issue. I think the challenge you're having is that its a slide dimmer, and for whatever reason, the slider is just falling down ever-so-gradually over time. They make another product (the AB-600M-WH) which fits in the same opening and works off of push-buttons rather than sliders.
Sep 23, 2010 | Lutron Toggler Single Pole 600 Watt Preset...
Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
Dimmer doesn't turn off! Right after I installed a Lutron electronic dimmer switch, it worked fine. After about a week, it wouldn't turn the lights off. The lights just dim to a low level at the lowest...
There is one more thing that you can try, turn the power off from the breaker and wait about 20 seconds, then turn back on. If that doesn't fix it you are probably right about the dimmer being bum. It is very rare that Lutron devices are defective. You can contact them directly and see if you can get it replaced since you no longer have the receipt. You may have to send it to them before they will send you a replacement but it beats spending another $50
http://lutron.com/CMS400/page.aspx?id=24679
Oct 17, 2009 | Maestro Lutron MRF-600MT Single pole or...
Electronic Low Voltage Master Dimmer
Home Depot sells Lutron dimmers which are single pole and basic.. www.homedepot.com
Apr 24, 2009 | Lutron Electronic Low-Voltage...
A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
Mar 23, 2009 | Lutron Maestro 600-Watt Multi-location...
What Kind of Dimmer?
If the low voltage lighting system uses an electronic transformer, then a dimmer designed for this type of transformer should be used. Likewise, if the low voltage lighting system uses a magnetic transformer, then a dimmer designed for this type of transformer should be used.
Aug 27, 2008 | Lutron TT-300NLH-BL Black Manual Lamp...
Universal Remote Control MRFB600MURCBL - Wall Box Dimmer Black Logo
47 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
