How to unstick a slide changing arm on a hanimex 2400eft slide projector
Projector worked well until suddenly the changing arm malfunctioned. I cannot get it to retract so that I can insert the vertical slide carousel
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
  • 412 Answers
SOURCE: problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
The carousel in my slide projector is stuck
I presume you are talking about a kodak projector. Look down into the center of the slide tray as it sits on the projector. There may be a small slot. Get a quarter, put it in the slot and turn it clockwise (?) a little, then lift the end of the tray furthest from the stuck slide. The tray should lift away. WITH THE RING ON, turn the tray over and rotate the metal bottom of the tray until it clicks, returning it to the "zero" position. Turn off the projector (if it's on) and retrieve the slide. Turn the projector on and hit the FWD button to get the arm situated correctly.
Dec 29, 2014 | Office Equipment & Supplies
Where can I find a replacement bulb (24V 150 W Q.I. type Hanimex Type A1/216) for a vivitar slide projector.
Try searching at www.bulbman.com or at a "Batteries plus Bulbs" franchise. Look on the lamp for a 3-letter code. This ANSI code is unique to the lamp and is a great aid in lamp identification.
Mar 14, 2013 | Vivitar Office Equipment & Supplies
Slide magazine to fit prinzauto
Hi these Prinz slide projectors are made by the same Australian company who makes the Hanimex brand ,they use both the 120 rotary mags and the 36 or 46 slide trays,the Prinz brand are made for the British market,ive bought a great Prinz concord auto still in its orginal box,where about do you live?
Jun 26, 2012 | Office Equipment & Supplies
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
All slides are fuzzy on my hanimex Rondette 1500 RF
If it is fair to make the assumption that the projector focussed slides correctly in the past,m then here are my suggestions:
- More than likely there is probably one of the optical components missing or out of position.
- The other thing that could be affecting focus is that the projector is too close to the screen, I would open the compartment where the optical components are located and check for proper position and cleanliness.
Good Luck !! jim
Apr 18, 2011 | Vivitar V5000AF Slide Projector
Where in Canada can I obtain bulbs for a Vivitar 2000AF slide projecter 24 volt 150w Q.I ( hanimex type A1/216
Try www.Bulbman.com. They have an amazing assortment of discontinued lamps! Good Luck !!
Feb 13, 2011 | Vivitar V5000AF Slide Projector
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
65 people viewed this question
jasbo
jasbo
