Question about Polar FT4 Watch
There is a number 2 in a circle on the time screen
Wenger model 097.0699 has a 3rd hand that relates to a series of numbers 1-24 on a inner circle what is this for?
dual time. You can set the inner hand with 24 hr markings for other time zone. So regular hands for your local time and inner hand for other country or time zone.
May 13, 2014 | Swiss Army Wenger Sportedge Bracelet Watch
Reset the time on a G shock GW 1500A
The least time-consuming method is to follow the instructions in the manual. Download the manual for the watch module from Casio worldwide site. The module number is a 4-digit number set inside a rectangle on the back of the watch. Usually on the periphery of the circle.
Nov 03, 2013 | Casio GW1500A-1AV G-Shock Atomic watch
Aeo watch instructions
To set the time and date (must be done in this order) 1. Press MODE 3 times, then press START to change the seconds. 2. Press RESET to change the minutes, then press START until you get to the right minute. 3. Press RESET to change the hour, then press START until you get to the right hour. Note: If it says "H" on the right circle, it should read 24HOURS, otherwise it should read "A" for AM and "P" for PM. 4. Press RESET to set the date, then press START until you get to the right date 5. Press RESET to set the month, then press START until you get to the right number. 6. Press RESET to change the day of the week, then press START untilyou get to the right day. 6. Press MODE when done. Hope this helps
May 28, 2013 | Watches
I don't have an instruction manual for Zoo York
have a zoo york watch and I can't understand the directions
Aug 10, 2011 | Watches
Need to take out a link or 2 to fit wrist. How do you remove the links
wrist watches links are made through two types of connection. First one is road based. the ends of the links are made in such a way that they make a round and interconnected with each other by sliding one link inside other then a thin road is placed in between the circle with spring loaded locking mechanism so that it shall not come out of the circle. In order to remove this type of link you are required to put the end of the link on a small hole and with the help of a small road tap the top of the road inside the links circle. Once the road is out you can slide out both the ends of the links and remove any number of links you wan't.
Second type of connection is made in half round type in this type one end of a link is made half circle and the other end is exactly same size hole the semi circle end fits inside the hole of next link. To remove the link you have to undo the semicircle part with the help of a plair and remove the link.
Dec 27, 2010 | Fossil Watches
Have a rotary chronograph watch from the 1990's with two set buttons on each side of the face. IE 4 in total. model number G3031. Uses battery UCAR399(both numbers on the back of the case). Asking if...
On the back of the watch there is a circle shape button like. To change the time, push that button like circle with a pointed object until correct time is shown. Check out.Thanks.
Jul 26, 2010 | Rotary LB00969/22
What are the dials for?
You have a divers watch it seems.
However - depending on the cost of the watch - they are most likely accents - and not working gauges.
One is for depth - one is for air time left - and the other for stopwatch
Without a model # or picture it is difficult to tell exactly.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 28, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Mar 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Polar FT4 Watch Logo
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
