Question about Dell Latitude E6510 Laptop Computer (Intel CORE I3 370M 250GB/1GB) (e6510sls2) PC Notebook
2000-0411 Express cable not detected
Im using a garmin cable to install express and it aint going
You need drivers from Garmin dot com.click detect, install drivers. Update. Register. And there is
Dec 27, 2015 | Garmin nuvi 1350 Car GPS Receiver
How do I get express digital core to detect my canon t5 camera? it keeps saying camera not detected.
Have you tried a different usb port?
Try setting it up via wireless if the cable is damaged.
May 12, 2014 | Express Digital Darkroom
HOw to get picture on my emerson tv..
Make sure the TV is on the correct input selection.
Oct 19, 2013 | HP NVIDIA GeForce 8400GS - Graphics...
How to wire up a 650 graphic card
You're going to need;
A) 2 miles of No.00 wire.
B) SpreadNok cable clamps
C) A pair of Klines
D) 2 rolls of black plastic electrical tape
OR,
your Power Supply needs a 6-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
Plug it into the Top/Back of the graphics card.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5247878&CatId=7387
(I watched the video)
Your PCI-Express x16 slot can deliver up to 75 Watts of power.
The 6-pin PCI Express power cable, can deliver up to 75 Watts of power.
Minimum of a 400 Watt power supply is needed.
Looking back at the Playtool link, and the 6-pin PCI Express power cable;
Note the 6-pin PCI Express adapter power cable, shown on the right.
THIS, is what you use if your Power Supply, does NOT have a 6-pin PCI Express power cable.
TWO 4-pin Peripheral power cables plug into it.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
I say again...............TWO 4-pin Peripheral power cables plug into it.
DO NOT use just one.
I don't care, if that is all the 4-pin Peripheral power cables that were left.
If you use just one 4-pin Peripheral power cable, you will;
A) Burn the gold plated contact pins on the bottom of the graphics card.
B) Burn the contact pins down in the bottom of the PCI-Express x16 slot.
C) Burn the plug connector end on the 6-pin PCI Express adapter power cable.
D) Burn the contact pins on the graphics card, that the 6-pin PCI Express power cable plugs onto.
Happen right away?
Nope.
Down the road a little after you have forgotten all about it.
("Hmmm, what's that smell? Smells kinda' like burnt wiring.
Wow, my monitor screen just went blank."
News at 6:00
"Nvidia GeForce GTX650 graphics card buried today, along with a motherboard.
Owner cited for neglect, pain and suffering.
Plea bargained to do better in the future" )
Not having a 6-pin PCI Express power cable on your Power Supply, suggests it is a low quality unit, and is underpowered for that graphics card.
Want to burn up a graphics card, just under power it.
[ 4-pin Peripheral power cable;
Also misnomered as a 'Molex' power cable.
Molex was the first company to produce that design of power cable CONNECTOR.
(I don't think they designed it, just manufactured it; if memory serves)
Name stuck. Kinda' of like calling an open-end wrench a 'Crescent wrench' ]
Regards,
joecoolvette
Apr 03, 2013 | Dell Studio Computers & Internet
Samsung monitor shimmer
Hello try to upgade the graphic driver with this tool:
http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
I sometimes help. But the screen/ or cable could have a fault.
Good luck
Nov 01, 2012 | Samsung SyncMaster 245BW LCD Monitor
My ATI firepro V7800 makes continuous beeping noise. PC does not boot when I turn it on.....pls help!!!
1) Believe the continuous beeping you hear is a BIOS Beep Code, stating you have a graphics problem. Computer, not video card, is beeping.
2) Do you have the external 6-pin PCI-Express power cable plugged into the graphics card, from the Power Supply?
3) IF, your Power Supply does not have a 6-pin PCI-Express power cable, are you using TWO 4-pin Peripheral power cables, connected to a 6-pin PCI-Express adapter power cable?
To wit;
6-pin PCI-Express power cable example, and also showing a 6-pin PCI-Express adapter power cable on the right,
Example of a 4-pin Peripheral power cable,
(Misnomered by many as a 'Molex' power cable. Molex was the first company to make that type of connector. The name stuck, kind of like calling an adjustable open-end wrench a Crescent wrench),
Note the color code of the wires used in a 4-pin Peripheral power cable, and a 6-pin PCI-Express power cable.
Red = 5 Volt wire
Yellow = 12 Volt wire
(All are DC Voltage)
Black = Ground wire. (ALL Black wires are Ground wires)
The 4-pin Peripheral power cable has ONE Yellow 12 Volt wire.
The 6-pin PCI-Express power cable has TWO Yellow 12 Volt wires.
The most power that a PCI-Express x16 expansion slot can deliver, is 75 Watts.
"This cable is used to provide extra 12 volt power to PCI Express expansion cards. PCI Express motherboard slots can provide a maximum of 75 watts."
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
"The older 6 pin version officially provides a maximum of 75 watts (although unofficially it can usually provide much more)"
The ATI FirePro V7800 graphics card requires 150 Watts by itself.
The PCI-Express x16 expansion slot CANNOT deliver the recommended power (Wattage) needed, therefore an external power cable capable of delivering 75 Watts is needed.
What happens if you just use ONE 4-pin Peripheral power cable, in a 6-pin PCI-Express adapter power cable?
The PCI-Express x16 expansion slot contact pins -> BURN
The gold plated contact pins on the bottom of the graphics card -
BURN
The connection on the graphics card for the 6-pin PCI-Express power cable - BURNS
The contact pins in the 6-pin PCI-Express adapter power cable -
BURN
If it is too bad, and cannot be remedied by cleaning, the motherboard is TOAST, and so is the graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 30, 2012 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
My system is not detecting my Hp photosmart express C3183 and i have change the USB cable, still it is not being detected
There should be a driver CD with that unit. Or, the driver installation might have been ruined. The power to the printer might be turned off, or it might not be connected to electrical power. But I'd bet on the driver being the issue.
HP.com also has all the drivers available for download.
Apr 22, 2010 | HP Photosmart C5180 InkJet Printer
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Logitech quickcam express problem soft
i require new driver for quickcam express 2 web cam please, know where to find one?
Oct 02, 2008 | Logitech QuickCam Express Web Camera
I have problem Video Capture form VHS
Try another computer and use that one to see if it would isolate the issue for your computer.
May 29, 2007 | ATI All-in-Wonder 2006 PCI Express ,...
Dell Latitude E6510 Laptop Computer (Intel CORE I3 370M 250GB/1GB) (e6510sls2) PC Notebook Logo
19 people viewed this question
Alun Cox
