Question about Measuring Tools & Sensors
Rendezvous transmission fluid leak - Measuring Tools & Sensors
3 Suggested Answers
godtech
  • 51 Answers
SOURCE: Transmission is leaking toward the middle of the car
CHECK TO SEE IF YOUR TRANSMISSION PAN GASKET IS LEAKING/IF NOT CHECK ALL HOSES AND LINES/IF NOT REPLACE YOUR REAR MAIN SEAL.
Posted on Jan 17, 2009
Ironfist109
  • 3018 Answers
SOURCE: 2003 rendezvous transmission fluid change
  • A full transmission fluid change, like as in a flush, requires 9.5 quarts of DEXIII/M transmission fluid.
  • If you are going to be dropping the pan at home to swap the filter and gasket you will not loos near full capacity of transmission fluid. For this you may loose 3 quarts (give or take a bit). 4 Quarts on hand would be plenty for this case.
  • Don't forget to (with you foot on the brake) run the transmission through the every gear for a few seconds to fill the pockets before you check the level. if you do drop the pan.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 14, 2011
What power steering fluid is for buick rendezvous 2002?
if you can't get regular power steering fluid you can use Dexron 3 transmission fluid for power steering.
Oct 14, 2014 | 2002 Buick Rendezvous
A 2002 Buick Rendezvous FWD transmission fluid change how much fluid do I need? I also discovered leakage, Do I change the gasket and pan as I am about to change the ATF filter?
Is the pan gasket leaking ? You would normally get a new gasket with the filter so the gasket gets changed too.
Most models hold about 4-6 quarts of ATF. I would start with 4 and add until the trans is full. Your torque converter does not get drained.
Mar 12, 2014 | 2002 Buick Rendezvous
Change transmission fluid buick rendezvous
just jack the car up go get 5 quarts of good quality transmission fluid ,,change the filter put in new fluid easy to do with the filters that are like the oil filters
Oct 26, 2013 | Cars & Trucks
2004 buick rendezvous transmission hesitates from a stop and bangs int gear.
There are very high chances of your transmission fluid emptying out or being very low. you should get that checked. I went through something similar and by the time i took my car to the garage to get transmission oil changed my transmission system was badly damaged.
hope this helps. good luck.
Mar 18, 2013 | 2004 Buick Rendezvous
Auto trans slips
Check for the fluid level. If it is low add fluid. Check for leaks. If it is not low, have you serviced the transmission every 50,000 miles? If not it is likely you have worn out the clutches in the transmission and it will need replacement.
Apr 22, 2012 | 2003 Buick Rendezvous
2003 rendezvous transmission fluid change how much fluid do i need?
Regards, Tony
Jun 14, 2011 | 2002 Buick Rendezvous
Have 2003 Buick Rendezvous cx, has 175,000 kilometers, the transmission seems to have a slip when you go from reverse to drive, but only once in awhile, what could this be.
Have you ever had the transmission fluid changed? If not, it COULD be the problem. Don't take it to one of those Fluid Flush places. They don't change the filter and just pump out some of the old fluid. Go to a place that drops the pan and changes the filter.
I also use SEAFOAM transmission conditioner shortly BEFORE I change the fluid. O'Reilly's sells it.
Good Luck.
Apr 28, 2011 | 2003 Buick Rendezvous
I have oil in the cooling system?????I also have about 3.5 quarts of oil in a verry shoet time.Engine runs good and does not smoke.Very little sign of leaking oil.What should i look at first.Intake...
It happened to my 2003 last year. My mechanic tells me that there is a transmission cooler built into the radiator that has cracked or somehow opened to allow the exchange of fluids. Cost me a new radiator, and flushing of both cooling and transmission fluids. 3 months ago the head gasket went. I don't know if it was related. Oh, and I had to flush the cooling system a couple of times as trans fluid remnants continued to show up in the coolant overflow reservoir. I recently checked my trans fluid, and it looks brown about 18 months later, might go for a BG flush soon. Car runs fine
Dec 31, 2010 | 2003 Buick Rendezvous
My 2003 Buick Rendezvous bucks upon stepping on gas peddle at times ..........not to mention I think its leaking transmisasion fluid also...
this is pretty vague considering your asking for specifics when there can be sveral problems for each question. You need to get this inspected before it leaves you stranded.
May 11, 2010 | 2003 Buick Rendezvous
Jan 06, 2009 | 2002 Buick Rendezvous
Measuring Tools & Sensors Logo
517 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
