Question about Dell Latitude D630 Notebook
Can't find jumper to remove password. - Dell Latitude D630 Notebook
How do I remove administrator password on the BIOS of Optiplex 390
The CMOS contains the current BIOS settings
  1. Turn off the computer and disconnect the power cable from the electrical outlet.
  2. Remove the computer cover.
  3. Locate the 2-pin password connector (PSWD) on the system board.
  4. Remove the 2-pin jumper plug.
  5. Locate the 2-pin CMOS jumper (RTCRST) on the system board.
  6. Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
  7. Plug in AC power to the system and wait ten seconds for the CMOS to clear.
  8. Move the 2-pin jumper plug back to the password jumper.
  9. Replace the computer cover.
  10. Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
Aug 15, 2016 | Dell OptiPlex 390 DT Desktop Computer...
Tip
Forgot you laptop password?
This tip will help those who have forgotten their bios password not windows password.
Your bios password is the password your computer asks for as soon as you power up your system. The windows password is the password needed to log onto your screen name.
If you have forgotten your bios password almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. E.G. If the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
on Jan 05, 2010 | Computers & Internet
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
I need to remove the bios password for toshiba Satellite A85-S107
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
Oct 18, 2009 | Toshiba Satellite A85-S107 Notebook
Please help me reset my bios password on acer travelmate 2410
First you need to remove the laptop battery at the back side. Find some screw there and remove it locate the CMOS battery and jamper.
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is.
If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
Oct 08, 2009 | Acer 4220-2346 Notebook
How to remove cmos/bios password ?
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
How to break bios password
remove CMOS battery for 1 minute then try to install it back
Jun 08, 2009 | Intel D945GCCR Motherboard
Delete bios password laptop nc6120
http://www.elfqrin.com/docs/biospw.html
Here is a link.
Dec 10, 2008 | HP Compaq nx6310 Notebook
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Dell Latitude D630 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
