Question about Philips Aquatouch At890 Wet And Dry Rechargeable Electric Shaver With Pop Up Trimmer
A life of it's own
Keeps switching on by itself
I brought my irulu tablet yesterday downloaded some apps and it started to freeze when I switch it off and back on it takes long to load and also resets itself
I had similar problem with HP tablet which was not answered by them. Later I found it has got DEEP DISCHARGE problem.ie. it is allowing the battery to go to deepdischarge stage due to circuit problem. The circuit should make itself dead and prevent the battery to go to that level. Virtually the battery enters into COMA stage ! Keep it in switch off stage for 48 hours with charging on - so that the battery comes to life again and charges itself. Later my tablet is OK.
Jul 30, 2016 | Tablets & eReaders
When I am downloading a film...I leave my PC on but when I go back to it after about half an hour it has switched itself off stoopping my download can you help please ty mike
There is little info on your problem but I think you mean the screen went black while downloading a film. Normally computer monitors turn themselves off (dormant) to save energy and the life of the monitor's screen if not used for 10 or 30 minutes, depending on the settings, but the download just keeps going. Mine is set to 10 minutes. All you have to do is disturb the Mouse and see if the monitor screen switches itself on. There is another power saving option, and that is the Computer itself. If the computer is not used for one hour, it too goes dormant, but can also be set to switch itself completely off after the download is completed. However, if a computer is left on for over an hour, it can switch itself off to save energy and the computer's own wear and tear. It all depends on the computer hardware and the settings. If it is hardware controlled, then it may or may not switch itself off but it still goes dormant. Or it can be set to whatever you wish it to do, stay on all the time, go dormant after a set time or switch off if there is no prolonged activity.
Jul 16, 2014 | Computers & Internet
Keeps switching itself off and on???
Provided that your lamp is not reaching the end of its life, there have been some issues with the lamp door switch opening due to thermal expansion of the plastic. I would bypass the two wire switch altogether to eliminate this possibility, it won't affect the operation of the TV. If the set still shuts down, and there is no on screen display mentioning a fan failure, replace the lamp. Part number is listed on the lower left side of the TV with red label.
Bill W
integrityhomeworx.com
Mar 23, 2011 | Samsung HLP5674W 56" Rear Projection...
My tv just turn's itself off and doesn't come back on for ages!!!
have a reputable shop check the "known to fail "power supply capacitors....they may not be filtering the power correctly to the main control board....that would be the next suspect
Jun 07, 2010 | Samsung LN32C450 32 in TV
My wii console keeps switching itself off
Check the Wii remote battery life. Dead batteries in Wii remotes can cause the Wii console to turn itself off. If this is the problem, remove the dead batteries and insert new ones. If they're rechargeable, recharge the batteries.
If this is not the problem, your Wii console might not be working properly. Visit support.nintendo.com or call 1-800-255-3700 for more information.
May 02, 2010 | Nintendo Wii Console
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
My Mobi-cam keeps turning off by itself. What is
This is from the Mobi Camera Manual
Q. What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Sep 17, 2009 | Mobi-Cam Mobi AV Monitor
I unlock my nokia n73 but the phone keep switching itself off during useage or after couple of hours on standby. What can I do?
Call you Service Provider and find out if there is a common problem with the particular model and its battery going flat, as this happends with many Nokia N95s. There could be a fault with your battery,
or what u consider small usage could actually just be the expected battery life for the phone, confirm this in the Manual.
also try - http://www.walkernews.net/2007/06/08/converse-nokia-n73-battery-to-standby-longer/
for some tips on making the battery life last.
May 31, 2009 | Nokia N73 Cellular Phone
Problem with garmin c510 st pilot
the update will not load... i had this problem.. i just took the memory card out and re-started the unit... works fine again... Dave
Aug 03, 2007 | Garmin StreetPilot c310 GPS Receiver
Philips Aquatouch At890 Wet And Dry Rechargeable Electric Shaver With Pop Up Trimmer Logo
24 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
