Question about Kitchen Selectives CM-202 Coffee Maker
Filter basket is pulling loose from the rim - Kitchen Selectives CM-202 Coffee Maker
How do I remove the filter basket from Cuisinart Programmable coffeemaker CBC-5200PC Series?
I have this coffee maker and the basket comes out with the grinding cup and assembly. It's all one piece and pulls straight up.
You may need to pull a bit harder.
Jun 11, 2014 | Cuisinart DGB-300 Coffee Maker
Will not balance
Make sure the inner basket "floats" up and down freely. Reach in and pull up on the rim of the basket. little force should be used to lift the basket off the hub. If not an overhaul might be needed. This is a common problem with earlier versions of these machines
Mar 10, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My clutch basket came loose as i striped it down i noticed the washer behind the nut that holds the basket on was quite abit big for the shaft then i pulled the basket off and there was a other washer...
Sounds like they were put in in the wrong place.. swap them..tighten with an air tool...the washer with the splines goes between the basket and the inner hub..the big washer goes behind the clutch basket.(goes on the shaft first)
Sep 14, 2017 | 2007 kawasaki KX 125
I've changed o-ring at pump basket lid, cleaned all baskets and filters, had the Hayward pool vac internal parts all replaced and can't get pool pump to **** enough pressure to run pool vac....
If you reach into the hole behind the basket in the pump. You should be able to use a screwdriver to feel around to see if something is clogging the impeller. If so you can work it loose by working it in a counter clockwise direction, than use long nose pliers to pull it out. If that is your problem
Also check all your hoses for leaks.
Sep 09, 2010 | Hayward 1.5 Hp Northstar High Performance...
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Filter basket wont open..is there a secret?
You have to pull it open from the side. Then, lift out the filter and the basket.
Aug 09, 2008 | DeLonghi DC110T Coffee Maker
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
Cant pull out filter
The cross grid piece separates from the spindle. Yank the filter basket upwards and it should all come
apart. Subsequent removals become easier.
May 02, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Coffee Makers & Espresso Machines Logo
21 people viewed this question
Top Kitchen Selectives Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Kitchen Selectives Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
