Question about OneRoof CyberCafePro Client
I am using home network, but the ccp clients cannot connect to the ccp server
I am using a home network but the ccp clients machines cannot connect to the ccp server
Tally erp 9 working slow
you have not mentioned the networking involved .?
how are the clients networked to the server ?
Are you using a switch or a hub ?
Are you using a fast ethernet connection 100 Mbs or 1000 mbs into server from a network switch ?
How fast ? 10 mbs will cause problem on five client machines sharing 10 mbs into a server
Jul 07, 2017 | Microsoft Windows 7 Home Premium 64BIT...
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Hi
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
CCP Server 6, hangs and not responding. It starts and detect clients but hangs when I click login, timecodes, etc....
This was simply an issue with CyberCafePro not being able to connect to their online servers. You can get the latest (online servers no longer used) version here:
CyberCafePro Downloads
Aug 01, 2011 | OneRoof CyberCafePro Main Control Station
What is proxy
Hi liverpool97.
Let me explain you about the Proxy servers.
In Computer Networks, a Proxy Server is a Server (a Computer system or an application program) that acts as an intermediary for requests from clients seeking resources from other servers.
A client connects to the proxy server, requesting some service, such as a file, connection, web page, or other resource, available from a different server.
The proxy server evaluates the request according to its filtering rules.
For example, it may filter traffic by IP address or protocol. If the request is validated by the filter, the proxy provides the resource by connecting to the relevant server and requesting the service on behalf of the client.
A proxy server may optionally alter the client's request or the server's response, and sometimes it may serve the request without contacting the specified server.
In this case, it 'caches' responses from the remote server, and returns subsequent requests for the same content directly.
Hope this helps.
Please let me know if you need further information about the Proxy servers.
I'll be glad to assist you.
Sep 21, 2010 | Computers & Internet
I am trying to downlaod something but i need to wright a proxy sever but i don't know what a proxy sever is or how to do it?
In computer networks, a proxy server is a server (a computer system or an application program) that acts as an intermediary for requests from clients seeking resources from other servers. A client connects to the proxy server, requesting some service, such as a file, connection, web page, or other resource, available from a different server. The proxy server evaluates the request according to its filtering rules. For example, it may filter traffic by IP address or protocol. If the request is validated by the filter, the proxy provides the resource by connecting to the relevant server and requesting the service on behalf of the client. A proxy server may optionally alter the client's request or the server's response, and sometimes it may serve the request without contacting the specified server. In this case, it 'caches' responses from the remote server, and returns subsequent requests for the same content directly.
A proxy server has a large variety of potential purposes, including:
1: To keep machines behind it anonymous (mainly for security.
2: To speed up access to resources (using caching). Web proxies are commonly used to cache web pages from a web server.
3: To apply access policy to network services or content, e.g. to block undesired sites
4: To log / audit usage, i.e. to provide company employee Internet usage reporting
5: To bypass security/ parental controls
Aug 01, 2010 | Computers & Internet
Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
Jan 29, 2010 | Pc America Restaurant Pro Express
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
NAT Router - Problem
No static on the client side, but it's a good thing to run the server static.
You could setup a VPN into the LAN where the client machine is connected.
Stacey
PC REPAIR
www.wvpcrepair.com
Oct 07, 2008 | D-Link Computers & Internet
Ristricted logging onto server when server is off
Hi
Thanks for the background info, this makes it easier for me to see what you need.
You need to disable your guest account if you havnt already done so.
The user is logging on with a cached version of the logon information, this is useful for when the server goes down but not in your case as you need to prevent this.
Another worrying aspect is that you allow all your users to log on using the same password. Very bad from a security aspect anyhow. It is better to change at least every 30 days. If they moan they will get used to it soon enough.
Go into group policy again and computer configuration>windows settings>security settings>local policies>security options and look for interactive logon:number of previous logons to cache - set this to 0. If the domain controller is not available and the logon info is not cached they cannot logon to domain.
Group policy can be overruled at the client end if they have admin priviledges so you may have to set this on the client pc also. But you need to test to see if it is required there. I have not used that particular policy but it should be ok just on the server. Your users dont have admin rights do they? Anyway good luck. You can set this by applying it to an OU or domain wide but if you want to target just this one pc then maybe if you put it in its own ou and apply it just there.
You need to create new policies rather than modifying the domain one and keep each policy for specific purposes so that applying them to ou's is easier, ie internet options policy, firewall policy, working hours policy etc.
Regards
Julie
Mar 26, 2008 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
Top OneRoof Computers & Internet Experts
David Payne
David Payne
Are you an OneRoof Computer and Internet Expert? Answer questions, earn points and help others
