Question about Xerox WorkCentre 6605DN
Cartridge not recognized - Xerox WorkCentre 6605DN
Tip
UN RECOGNIZED EPSON PRINTER CARTRIDGES
There are a tweaks on cartridges that cant be recognized:
Try to follow these steps:
if a particular cartridge appear to be unrecognized : Try to perform a cartridge replacement using your computers printer software maintenance option.
follow the steps then remove the affected cartridge. remove it then install it back in. this will force the printer to recognize it along with computer which syncs its chips as you noticed which is seen on every printer cartridge.
now let your printer driver (as called for software) let it charge by clicking on the computer not on your printers charge buttons.
This usually works with expensive black inks that are not being recognized
on Jan 16, 2010 | Office Equipment & Supplies
Leappad won't recognize game cartridges and when it does, the screen goes black and returns to home page
I used the pencil eraser first on each of my daughter's cartridges. Then I used a qtip to rub them with rubbing alcohol. Finally I used a blow dryer to blow out where the cartridges are installed and now her games are working just fine.
Dec 29, 2012 | LeapFrog Leap Frog My First Leappad...
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
Cannot recognize cartridges yet they've been working for a while
Model number of the printer?????
check the supported cartridges...
psl align the cartridges.
May 08, 2010 | Office Equipment & Supplies
Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Nov 17, 2009 | Epson Office Equipment & Supplies
Color cartridge is not recognized
You can't.The printer needs to recognized both cartridges to print, scan or copy.In your case the color cartridge is defective.You must replace it for using your printer.
Oct 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
Xerox WorkCentre 6605DN Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
