Question about Philips DVDR3380/05 DVD Recorder
Manual do dvdr3380 - Philips DVDR3380/05 DVD Recorder
Philips dvdr 3380
The dvdr3380 has an analogue tuner. It doesn't pick up digital TV.
Your TV picks up digital, but it isn't designed like a TV/cable box to be a signal source to an external device.
If you want to make TV recordings on to the dvdr3380, then you need to buy a TV tuner box (Freeview/Freesat etc) and connect that to your aerial system and to the line input of the dvdr3380.
Aug 18, 2014 | Televison & Video
What is the recording time for philips dvdr3380/05 dvd recorder
Depends on the media you use. Normally a DVD can hold 4 GB of data and depending on the compression, format you choose it should hold some 2 to 4 hours of video-audio.
Mar 04, 2011 | Philips DVDR3380/05 DVD Recorder
Have "inherited" a philips dvdr3380/05 from our daughter but she's lost the manual (ps - it was ours in the first place and we gave it to her - there's gratitude!) Now I can't remember how to install...
quick-start guide:
http://download.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_qsg_eng.pdf
user manual:
http://download.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Sep 06, 2010 | Philips DVDR3380/05 DVD Recorder
Looking for manual for DVD 5980/12
http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=21710B212C5363AE2AA3CF847A1B06BD.app106-drp1?_dyncharset=UTF-8&country=&categoryid=PLAYERS_RECORDERS_CA_US_CARE&userLanguage=en&navCount=1&groupId=SOUND_AND_VISION_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Players+and+Recorders
Cut and paste the link above
Apr 18, 2010 | Philips DVDR3380/05 DVD Recorder
No manual can I get one
This user manual can be downloaded from
http://tv.manualsonline.com/manuals/mfg/philips/dvdr3380.html
Apr 10, 2010 | Philips DVDR3380/05 DVD Recorder
When i press to eject it does not open
There is a manual release underneath look for a slotted hole near the front slide this across with a small flat head screw driver, this will release the tray.
Oct 31, 2009 | Philips DVDR3380/05 DVD Recorder
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Need to unlock Region code
hello dunahaga
you can tyr here for region codes Philips DVDR3380 region code
riz.
Mar 25, 2008 | Philips DVDR3380/05 DVD Recorder
Philips dvdr 3380/05
Go to www.p4c.philips.com
After setting you language/country options, enter the model number and search.
From the list select the model with your country code after the "/"
EG dvdr3380/05
Click on "User Manuals", then select the relevant file to download from the right hand window.
The manual can be downloded
Jan 20, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
