Question about Lands Phones
How can program my nec topaz aspila in dial block, caller id, and call waiting feature?
  • 43 Answers
SOURCE: caller ID Display
This one could have different variables.
  1. your CO lines must have CID
  2. your CO card in the system must have CID capability
  3. older systems have a limited number of extensions that can display CID (16)
  4. your ext must be set to ring.
Posted on May 09, 2008
cnavarro
  • 2460 Answers
SOURCE: Caller ID?
No. I think the Prostar was mid 1990's manufacture. It was replaced with the 50si and DCS family. IIRC the 816 phone is not compatible or ugradable to any of the newer product.
Carl
Posted on Sep 08, 2008
  • 63 Answers
SOURCE: Caller ID for NEC Electra Professional Level I System (KSU)
only if your key system has caller id cards installed.
Posted on Feb 07, 2009
  • 17 Answers
SOURCE: StarTalk Flash is 1.7.00 + caller ID
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Hope this helps.
Posted on Mar 24, 2010
SOURCE: olympia caller ID globe
i dont know what is the answer....im so sorry for that...i have question...who post this question?
Posted on Jul 27, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do I make the green flashing light on the phone go away?
Blinking Light
Two reasons the light on top of your screen might be blinking or on steady.
  • You do not have a voicemail key programmed and the voicemail is alerting you of a new message. Simply dial *8 and check your mailbox.
  • Message waiting has been activated. To cancel:
    • leave handset hung up
    • press call1 key
    • dial 873
    • press speaker key
Blinking light on top of Display NEC Aspire
Nov 13, 2014 | NEC Lands Phones
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
Apr 18, 2013 | NEC Electra Professional ETW-16DC-2
WE HAVE NEC PHONE SYSTEM AT WORK. MY PHONE DOES NOT SHOW CALLER ID. HOW DO I ACTIVATE THAT FEATURE?
You cannot unless you subscribe to Caller ID from your loca ltelephone company. That is a feature that you .have to pay for
Feb 24, 2011 | NEC Electra Professional ETW-16DC-2
Give me the puk code for an 02 lg ks360
Hi All
I want to know about the NEC Aspila TOPAZ automatic Night mode programmers.
Pls tell me How to program in the KEY Phone.
STEP-by-STEP.
UDAYAKUMAR
ukpenieltelecom@gmail.com
Oct 31, 2010 | Lands Phones
How can I unlock my phone if u dont have the pass key?
For this you must go to security feature and unselect the 'Block Dial Out' and Block International Calls' feature. For this you will require a passwd, which I am sure you do not have. If that is the case then you will have to get the firmware re-installed.
Aug 19, 2009 | Lands Phones
NEC Dterm 80 phones
Caller id would have to be truned on, in system programming, as long as the caller id card is installed. If it works for the corded phones and not the cordless phones than, the analog caller id feature needs to be programmed. check out ldtsnj.com
Apr 13, 2009 | NEC DTU 8D-2 Corded Phone
Phone system does not accept blocked caller ID
Wow, that really tests my memory...oh wait. I have it on a bookmark :-)
http://www.tech-faq.com/lass-codes.shtml
The phone system isn't blocking calls, your phone company is.
Try *87 or *68 and see if that works. You dial it into line #1.
Anonymous Call Rejection is the telco feature.
Carl
Mar 30, 2009 | Panasonic KX-T7633 Corded Phone
Electra professional nec
I am making the assumption that only line 1 has caller-ID. Both of my suggestions require services on the phone lines themselves, and not thru the phone system.
  1. Line 1 needs features on the line to allow three-way calling. Then you would hit the Recall key after answering to send a Flash to the Central Office to dial the 2nd number. This takes the transfer away from the phone system and puts it on the CO. This requires more time and effort on the staff answering phones, and if a calls comes in while this is in progress, it's going to roll over to another number in the hunt sequence anyway.
  2. Get Caller-ID on all lines.
Jan 11, 2008 | NEC Electra Professional ETW-16DC-2
Lands Phones Logo
412 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
