Question about Drills
REQUIRE A BATTERY FOR A BD0405B CHELLENGE - Drills
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
The initial charge can require several hours, sometimes overnight. After that, recharges require less time. If your device doesn't turn on unless connected to the charger, the battery may be dead.
Apr 18, 2016 | Vector Camping, Backpacking & Hiking
What voltage does the car charger require?
All car chargers require 11.5 to 12.5 volts. A car battery is rated as a 12 volt source, but voltage drops when you start the engine and rises when the engine is running and the battery is charging.
Feb 02, 2016 | Vehicle Parts & Accessories
Can't find battery on my bt 49 moped
Does it have a battery, or do the lights only work when the engine runs? I f this is the case then like most mopeds they don't require a battery,as they only require a power source from its generatorwhich only works when the engine is running.
Mar 11, 2014 | Motorcycles
Need to change the battery, stuck at a store. Tools needed and location of battery would be awesome. trying to make battery change asap
Depending on what model bike you have, the battery will either be under the seat or under a side cover, usually the right side cover. Screws differ. Some require a phillips screwdriver others require a flat screwdriver and some require a 10mm or 8mm wrench.
Aug 15, 2011 | Yamaha V Star Classic Motorcycles
I did not receive instruction from amazon and can't it to work. does it require a battery
Does not require a battery, gets its power from the USB.
You might start by downloading the manual:
http://www.logitech.com/repository/1412/pdf/12983.1.0.pdf
As long as you have Windows XP SP2 or later, the drivers are already a port of the Operating System.
Apr 27, 2011 | Logitech ClearChat Pro USB Headset
I have an MP-cs187 how do I charge it?
I beleive this model of MP3 player are not rechargeable as you require the use of an external battery for it. It takes a AA battery.
You may use AA rechargeable battery but you will require a charger for these.
Mar 03, 2011 | MPMan MP-F75 MP3 Player
Require replacement battery door for Canon EOS 40D
well if it doesn't work just with the battery doors - you can always get a battery grip. battery time will increase and you will not see that the battery door is damaged.
Jun 15, 2010 | Canon EOS 400D Digital Camera
Second hand moving in 4 second increments instead of 1 second clicks. Does this mean it needs service or just a new battery?
This means it needs a new battery. But if your watch is about 5 years old it is best to have it serviced. The oils in the movement will be drying out and this causes the gear train to require more power from the battery to make it move. By drawing more power from the battery, the battery will not last as long. This shortening of the battery life continues until the watch is serviced or eventually a new battery will not get the watch to run.
All watches require regular service to stay working properly.
Hope this helps,
Ken
www.YellowStoneWatch.com
Apr 10, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
How do you change out the battery in a 2006 Nissan Frontier crew cab NISMO
Hi, this is really not to bad to do. To remove the old battery take a ten mm wrench and loosen the battery cables. Always disconnect the positive cable first. Then the negative. When reinstalling the cables do the negative last. Most of the battery hold downs are the type that go over the battery. These require a 10 mm to remove. If you have the type that is at the base of the battery it will require a 12 mm socket and an extension. Thanks
Aug 08, 2009 | 2006 Nissan Frontier
The battery goes dead in the cold on my 2004 dodge ram 2500
Hi and welcome to FixYa,
Initially and not knowing if the battery is new, possibilities are:
  • one or more cells of the battery is weak, would therefore require replacement (most likely);
  • one or more of the diodes in the alternator has an electrical leak, and therefore would require check, repair or replacement (just a possibility).
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | 2004 Dodge Ram 2500
Drills Logo
55 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
