Question about iPhone Apps
Teamlava customer support
Id - lvenier I am at level 157. It tells me I need 13more stars to open, however I had 11 out of 18 stars from previous level to move on. I can't get 13 more stars, I can only gain 7 to have a maximum number. This happened once before at a different level but the problem finally resolved itself and I could move on. This time I have been locked out for several days and it will not let me move to the next island level. Please help
  • iPhone Apps Master
  • 607 Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave stopped heating!
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Concerning the problem Guest is having with the fan coming on when the door is open.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Concerning the original problem of no heating:
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 26, 2007
SOURCE: Scroll lock on Logitech LX 710
1. Click on Start and click on "Run"
2. Type osk and click OK.
3. You will see the On Screen Keyboard (OSK)
4. If the "nlk" button is white, it will be a visible key on your keyboard. Blue is when the key is not visible and the dark blue with the red border when the NumLock is ON.
5. Please make sure the "nlk" button is blue.
6. You will also the display on your monitor when the slk button is clicked or changed on the OSK.
Posted on Jul 15, 2008
SOURCE: Radio turns off by itself
I have a 1994 Jeep Grand Cherokee and radio turns itself off without intervention!!
Posted on Jun 24, 2009
  • 30 Answers
SOURCE: my lg phone keeps turning itself off
1.try making sure the battery always makes contact all the time(if not contact - add some paper for example)
2.the battery should have over 2 lines... (i guess you have charged it many many times)
3.try to update your firmware (software version) from www.lg.com - it should take about 30-60 mins
4. if nothing works, go to a professional service or something like this
Posted on Apr 23, 2010
Macmarkus
  • 2605 Answers
SOURCE: My washer is flashing E:13; locked with wet clothes inside
Hello and welcome to fixya.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump...just hoses as you did mention.
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Posted on Jun 13, 2010
Testimonial: "Thank you! Ten p.m. on a Sat. night...no help in sight...you helped us fix the problem on our own. Thank you so much!"
How do I get my account back and use my storm ID?
Have tried to look through your emails about your store ID
Jan 15, 2015 | TeamLava iPhone Apps
please email support@teamlava.com
Jul 11, 2014 | Acer Tablets & eReaders
I cannot access to the game once complete level 152 before move to level 153
Perhaps you can contact mfg. re:loading issue. hope this helps, Gene
Jun 16, 2014 | TeamLava Farm Story
How do I tell if my 2006 Yamaha v star 1100 is a custom or classic?
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Star Motorcycles
difference between yamaha classic and custom motorcycle
Yamaha XVS1100 Service Manual
OEM parts for Yamaha
Yamaha XVS1100R Owner Manual
May 07, 2014 | 2006 Yamaha V Star 1100 Custom
Faulty oil pressure switch on 2002 yamaha v-star custom
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Faulty oil pressure switch on 2002 yamaha star custom Google Search
Oil pressure light
Jul 02, 2012 | 2002 Yamaha V Star 1100 Custom
New ipad, download farm story. Able to get out to internet .. to google and other sites, can get corporate email fine, but farm story is telling me I have no internet connection
i would try to connect to a different wifi (I.E. starbucks or like mcdonalds free wifi) and see if you can connect. if you can than it may be that you may need to open some ports on your wifi router at home. if you can connect to a different wifi contact me back as i will try and open your ports for you.
Aug 26, 2011 | TeamLava Farm Story
My yahoo account has been block.
my id rohitavision@yahoo.com this id is block plz open my id
Jan 20, 2009 | Yahoo Mail
iPhone Apps Logo
1,766 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
