Question about Dacor ECS130 Epicure Electric Single Oven
Dacor range does not work - Dacor ECS130 Epicure Electric Single Oven
F-1 showing on digital window of dacor dual fuel range with oven alarm beeping. Unit is turned off.
Your temperature censor may need to be replace. try geting the fault code diagram from the manufactor brand.
Nov 14, 2013 | Dacor Ovens
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
Dacor range (oven)does not work
I have had the same problem for ten years. After a few years of the tech coming out everytime
I self cleaned, I had him show me how to reset, and he also gave me a new reset gizmo in
case that doesn't work. As for resetting, the top plate on top needs to come off and then you'll
see the gizmo with a dark red reset button that is attatched to the floor of that top compartment, which I leave unattatched for easier access. Push button down, of course turn off the electrical power to oven before doing all this. Works everytime.
May 29, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor cps130 wall oven f1 error
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Dacor MCS130 Millennia Electric Single...
Error codes on my Dacor Range -
Both of those codes suggest a bad membrane switch assembly. i dont specifically remember what the f1 error is, but the f0 error is "stuck membrane button" The membrane switch is just the touch panel, and usually run in the mid $200 range for the part. Its fairly easy to change, just label all your wires when you pull em off so you know what direction they go in. some of the connectors CAN BE put on backwards, so just make a good diagram or whatever to get em right. Good luck!
Jun 17, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECS130 Epicure Electric Single Oven Logo
27 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
