Question about Bose Lifestyle Model 20 Main Board 25, 30 Display Fix, Everythimg Works 100%
Bose lifestyle 30 display problem - Bose Lifestyle Model 20 Main Board 25, 30 Display Fix, Everythimg Works 100%
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
cjackHD
  • 71 Answers
SOURCE: bose lifestyle fault code 802
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
Posted on May 31, 2009
Bose lifestyle 30 will not come on
www.bose.com/controller?url=/customer_service/...
Jun 17, 2014 | Bose Lifestyle 30 System
Hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Apr 30, 2010 | Bose Lifestyle 30 System
My Bose Lifestyle 18 menu won't display on my tv
Take out the power cable from behind your BOSE system, wait 30 seconds and replug the power, this way the Bose system will reset automaticly and you'll see the menu appear again on your tv screen.
Worked for me
Nov 07, 2009 | Audio Players & Recorders
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
I WANT TO CONECT MY LAP TOP TO MY LIFESTYLE 30
Go to Radio Shack and buy a cable with two phono plugs on one end and a 1/8" jack on the other end - they're pretty cheap.
Put the phono plugs into the AUX sockets on the back of the Bose, and the 1/8" jack plug into the 'headphone out' jack socket on the laptop.
Be sure that the display says you're in AUX mode. This works for me.
Good luck.
Howard.
Sep 14, 2008 | Bose Lifestyle 30 System
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Jan 26, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Dec 22, 2007 | Bose Lifestyle 38 System
Bose Lifestyle Model 20 Main Board 25, 30 Display Fix, Everythimg Works 100% Logo
14 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
