Question about Rolair Rol-Air 6590Hk18 6.5Hp Gas Belt Drive
RUNS 20 MIN LOADS MOTOR AN SHUTS DOWN - Rolair Rol-Air 6590Hk18 6.5Hp Gas Belt Drive
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Dryer runs for about 20 min. then shuts off will start after it cools down and run again for another 20 min.
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out.
Sep 19, 2011 | Kenmore 66832 Dryer
Air massage runs 20 min. then shuts down. when I restart it right away it only runs a short time.
air systems have a built in timer on them. 20 mins.
they are supposed to be shut off for 20 mins to cool the blower down then can be turned on again.
Feb 13, 2011 | Maax Home
My sears dryer will shot off when iy gets hot,going through its cycle. If i let it cool down for about 10 mins. I can restart and continue for another 20 mins before it shuts down again
Take the exhaust vent off the rear and try it.
If it runs OK,repair the vent blockage/restriction.
If it does not run OK,replace the motor.
Sep 27, 2010 | Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Changed thermal fuse and cleaned out drier. it ran good for about 20 minutes and then shut down again. what could be the problem
changing the thermal fuse was a good idea but if the dryer runs for 20 min. then shuts off that is generally the motor going into thermal overload....thus meaning you would need a new motor.
Oct 02, 2009 | Maytag PYE2300AY Electric Dryer
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Htr shuts off after awhile and won't come back on till it's cooled down
I believe your heater has a solid state relay to start the motor when the motor gets to speed it is supposed to shut off. It may be stuck in the on position.
Jan 20, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Rolair Rol-Air 6590Hk18 6.5Hp Gas Belt Drive Logo
23 people viewed this question
Top Rolair Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Rolair Air Tool and Compressor Expert? Answer questions, earn points and help others
