Question about Nautilus T916 Treadmill
Tradmill belt tight and still slipping - Nautilus T916 Treadmill
Snow blower works great but belt keeps burning and getting loose.
Hi Alan:
A burning belt is usually an indication that the belt is slipping.
Slipping can occur as a result of it not being tight enough, or because it is experiencing load that exceeds the friction that exists between the belt and the drive pulley.
I would check the belt tensioner (spring) to make sure it is adjusted TIGHT, and try to avoid really loading up the auger/fan assembly.
Hope this helps.
Cheers
Jan 26, 2016 | Garden
Trying to figure out why i am having squealing issue all new altternator power steering pump pulleys and belts
Belts normally squeal when they slip and they slip because they're not tight enough or in the case of a V belt because they're too narrow. Make sure they're tight enough and they're the right belt.
Mar 10, 2012 | 1987 Cadillac Brougham
Pro form 400gi belt adjustment
should be a allen wrench adj on the rear of the tradmill
Nov 11, 2011 | Exercise & Fitness
The belt is tight why does it still slip
Hello, If the walk belt is tight, you will want to remove the motor hood and watch that the drive belt and motor are staying at the correct speed when the walk belt slips. The most likley cause is the front drive pully on the front roller. This sometimes looses adheshion with the front roller and slips, usually when you are running. After it gets reallt bad it will slip when walked on.
Hope this helps.
Feb 03, 2011 | Cadence Weslo 927 Treadmill Walking Belt
The belt is squealing like it's slipping, but appears to be tight, can it be too tight?
To tight should not cause squealing, if it is a serpentine belt check the splines on the inside if they come to a point or are sharp then the belt is wore out. They need to have a flat spot on each spline to keep it from slipping.Hope this helps.
Please take a moment and rate my answer.........Thanks
Dec 01, 2010 | 1990 Ford F150
After a few minutes of using my vacume it starts to smell like burnt rubber. like the belt is burningthe only belt I can see looks fine and is turning the brush
but how tight is the belt and how easy is the brush to turn? if the belt is slopy it will slip on the motor drive spindle,,,and it will get very hot then,,, also if the brush head is tight that makes the belt slip too,
Aug 11, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Timing belt on 1996 mazda protege slips during startup
Hello, this to me sounds like your fan belt slipping (not timing belt). To adjust the fan belt you need to undo your bolt on the alternator, pull it tight onto the fan belt and while holding it tight do the bolt back up tightly. this will stop yoour fan belt from slipping. I hope this helps.
Nov 06, 2009 | 1996 Mazda Protege
Feels like belt is slipping when in use. Would
tighten evenly until it stops slipping when your on it
Oct 15, 2009 | Exercise & Fitness
Slips once and a while
Ther are two adjustments to check,the tightness of the walking belt(the screws at the back of the treadmill) and the tightness of the motor drive belt under the motor cover.
Aug 15, 2009 | Life Fitness 9000 Next Generation...
I tighten the screws behind the belt but it still slips as i walk
Sounds like the motor drive belt is slipping,remove the motor cover,be careful some models have hidden screws in recessed areas underneath if you remove the correct ones the hood comes off easily. There is a bracket that has a bolt to adjust the motor belt tension.Also if you tightened the walk belt up it may be too tight which could cause it to wear or tear easier,the rule of thumb is tighten the walk belt just tight enough so it doesn't slip.
May 15, 2009 | Nordic Track /proform Treadmill...
Nautilus T916 Treadmill Logo
16 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
