Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis francis thermostat cold - FrancisFrancis! X1 - Stainless Steel Espresso Machine
Espresso maker continually leaks when heating
Most likely a gasket problem. But you say that it drips water while it heats. Try it without the coffee holder; it shouldn't leak.
Jul 16, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Have a Francis Magic L'Espresso X1 76015.. While it still gets hot enough to make coffee, the thermosstate reads about 59, where it used to reach over 110. Any advice please?
Is the coffee good? It's most likely the thermostat. Inside the thermostat sensor is stuck into a hole in the boiler; if it gets detached the thermostat won't work but the coffee machine will. Mine hasn't worked for years but the coffee still tastes fine.
Nov 01, 2012 | FrancisFrancis! Coffee Makers & Espresso...
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
I need to replace the boiler or heating unit in Francis Francis x5
Sounds like the thermostat is going out.. ...Check out holiday house .com they may have parts.
Nov 10, 2011 | FrancisFrancis! X5 Espresso Machine
I have a Francis Francis X5,it brews fine, but steam wand is not producing/ maintaining pressure. Any ideas what causes this, and how much for repair?
This type of espresso machine has two thermostats: one for brew mode, and one for steam mode.
It sounds like you need a new steam thermostat.
Mar 04, 2011 | FrancisFrancis! X4 Espresso Machine
Boiler gets too hot
Hi Contact Francis/Francis because you need power board.
Apr 12, 2009 | FrancisFrancis! X5 Espresso Machine
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
