Question about Honda 1999 Passport Window Regulator, Rear g67714567m Electric San Francisco, California
I need to replace the rear shocks on 1999 honda passport
motor1258
  • 6674 Answers
SOURCE: where is throttle position sensor located on 2000 honda passport
Normally attached at opposite end of throttle linkage. Remove your air cleaner intake hose at throttle body, and observe throttle plate that opens & closes as you press accelerator, it will be at the end of that, on outside of housing.
Posted on Jan 10, 2009
SOURCE: right rear shock absorber detached from the top mounting point
Turns out that after 26 years and 233 thousand miles, the original strut gave up the ghost: Rust! I took the shock strut assembly out of a 'spare parts' Honda Accord I keep and replaced the broken one in the Honda I am now driving. Mechanically the car is still excellent, but the car is destined to dissolve around me! To remove the whole assembly required taking out one 14mm bolt at the bottom and three 12mm bolts at the top, some WD 40, several pieces of wood for leverage and a heavy mallet.. Since there is a heavy duty coil spring involved, one should take out the bottom bolt first and lift the bottom of the strut free from its position, ( this is where I used a long 2x4 and another piece of wood as the fulcrum point to pry the strut upward) Then undo the top 3 bolts and the whole unit falls out. You will also need to detach the brake fluid line that uses the strut itself as an anchor. The easiest way is to take the line off from the back of the brake drum housing ( 9mm nut) and remove the horseshoe clip and push the curved metal brake line through the small hole where the line is anchored to the strut. Use care as you will need to reattach the brake line again after installing the next shock strut. (Coil spring compression tool required) Needless to say, you will need to jack the car up and remove the rear tire first to access the whole thing.
Posted on Apr 10, 2009
Mr BrokRench
  • 1623 Answers
SOURCE: rear shock oil 1985 honda aspencade
Hello thor67...your wing should hold 300cc's per side.
Tip: suggest useing 15wt fork oil instead of the ATF that mother Honda recommends.
Hope this helps...ride safe...ride smart.
Posted on May 14, 2009
honeymokey
  • 3113 Answers
SOURCE: I cant remove a rear axle seal to a 1999 honda passport
Axle bearing and seal are made together. It is pressed on axle.
Posted on Aug 26, 2009
  • 713 Answers
SOURCE: 1999 honda passport. clunks when stopping and a
have the rear chunk and front chunk checked out could have slack in gears.
Posted on Aug 28, 2009
2007 Honda CG 125 remove spring from rear shock absorber
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Remove Spring of rear Shock Absorber of 125 CC Motor Cycle
Motorcycle rear shock absorber removal refit replace
HARTFORD CG125 CG150 ENGINE SERVICE REPAIR WORKSHOP MANUAL 1999 ONWARDS... $10
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 24, 2013 | 2007 Honda CG 125
2000 Honda VFR 800 rear shock removal
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Fast Answer For Rear Shock Removal Needed
Rear shock replacement
1998 2001 Honda VFR800FI Service Manual VFR800 Moto Data Project
Honda 1999 VFR800FI Owner Manual
Nov 16, 2013 | 2000 Honda VFR 800
1999 Honda VT 1100 C Shadow Spirit adjust rear shocks
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rear Shock Adjustment
shock adjustment the tool
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Oct 07, 2013 | 1999 Honda VT 1100 C Shadow Spirit
Where is the fuel filter located on a 1999 honda passport?
follow the fuel ine from the gas tank under the car, as I recall it is along the side rail of the frame under rear seat area just forward of the rear wheels...
Sep 15, 2010 | 1999 Honda Passport
Is the 1999 honda passport a front wheel or rear wheel drive vehicle when the 4WD is not engaged?
Rear. In Europe was on sales until 2003 (last line made) by OPEL as frontera. Equipped mostly with 2.2 Turbo diesel engines, rear wheeler, ability to engage 4WD, under motion up to 60MPH, having automatic front diff locks, and despite the bad critics about crash tests and behaviour, well sold. Still on the roads.
Aug 19, 2010 | 1999 Honda Passport
Aug 28, 2009 | 1999 Honda Passport
Aug 18, 2009 | 1999 Honda Passport
1999 passport leaking fluid from rear end
Mostly likely the differential seal.
Aug 07, 2009 | 1999 Honda Passport
Rear axle is bent
Go-To Car-Part.com
http://www.car-part.com/
Type the year (2000), and make (Honda Passport).
Search for Axle Assy Rear
Ignore 4x4 and focus at 4x2.
You must know the ratio - teeth (41/10 teeth, GT5) or (43/10 teeth, S7C)
(3.2L, 6 cyl, disc), 4x2 (drum brakes), 4.10 ratio (41/10 teeth, GT5)
(3.2L, 6 cyl, disc), 4x2 (drum brakes), 4.30 ratio (43/10 teeth, S7C)
1999 - 2002 Isuzu Rodeo - Honda Passport.
You can get an USED one for $600 plus shipping.
Good Luck.
Jan 04, 2009 | 2000 Honda Passport
Honda 1999 Passport Window Regulator, Rear g67714567m Electric San Francisco, California Logo
613 people viewed this question
Top Honda Insulation Experts
Tim Hunt
Tim Hunt
rhodesworks
jeni
jeni
Level 1 Expert
Are you a Honda Insulation Expert? Answer questions, earn points and help others
