Question about Sprint Motorola 4G Clear Aircard Desktop Modem CPEI25150 DSLRadio Modem
Cpei25150 How can I tell if my modem is compatible with time warner? I don't want to lease one since I already own this one, but I'm not sure if it can be used.
Bought the same identical modem that time warner provides & had them register it.enabled wireless & rebooted modem. wireless disables when you connect time warner says everything is good on their end
The configuration between the modem and your computer requires digital switching via code settings. Check you manual for the proper communication settings.
Mar 30, 2015 | Arris Computers & Internet
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
I have a Motorola surfboard sb4100, i used it before so i know it works. In fact it was with adelphia, when they were around in my area. Now we have time warner. I tried it before, with time warner and it...
You need to call Time Warner and tell them that you need to activate your modem. I had to do this when I switched modems for Comcast, so this should solve the problem.
Mar 06, 2011 | Arris SURFboard SB4100 Modem
I purchased a new computer from Dell desktop Studio XPS 7100 I use Road runner internet...I want to run 2 desk tops at the same time.. is it better to get a router from Time Warner or buy it frim Dell?
It doesn't make much difference the brand of the router that you decide to get, just look into the specific model of router to make sure that it is compatible with your specific Dell system
Oct 12, 2010 | Dell (0E828) for Latitude C610 Modem
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
I leased a computer from Gateway in 2004 and the lease is up. How do I found out about returning the machine OR buying it outright? I have phoned at least 15 times to find out. No one can hook me up...
Try going through the support section of Gateways website. If you can get someone through that they should be able to tell you the procedure for lease termination.
After four years on lease I think you probably MORE than paid for the system already. If you still can't get ahold of anyone through support, I'm sure once lease payments stop coming in, they'll contact YOU. At that time you can find out the information you seek.
Hope this helps
Dave
Nov 06, 2008 | Gateway Computers & Internet
I installed Netgear wnr834b on time warner cable. it works for a minute but then power and link lights go orange and i lose connection. have replaced router but still same thing. also replaced modem and...
If you already replace the modem and the router so it only means that the problem is with your Time warner internet connection line , did you already contact time warner and let them check your internet line to make sure the signal from them is strong and working fine if not contact them...
Oct 24, 2008 | Computers & Internet
Sprint Motorola 4G Clear Aircard Desktop Modem CPEI25150 DSLRadio Modem Logo
46 people viewed this question
Top Sprint Computers & Internet Experts
Computer Repairing
Computer Repairing
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
