Question about GE XL1800 1100 Watts Microwave Oven
Buzzing noise When plugged in buzzing stArts and doesn't stop. S
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
Why would my microwave be buzzing, I just got it for Christmas and I can't leave it plugged in because it constantly buzzes?
There are loose laminations in the transformer causing the noise. A replacement transformer will stop the noise or indeed re-crimping the cover on the transformer will possibly clear the noise.
Oct 24, 2010 | Kenmore 66222 Microwave Oven
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Buzzing noise, wont work???
The magnatron is shorting, overloading the high voltage transformer. From the picture this looks like an older unit and is probably not worth a magnatron replacement.
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Ginding, buzzing noise
sounds to me like the magnatron stopped working.
Dec 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
55 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
