Question about HP Compaq dc7100 PC Desktop
Replace battery on dc7100 - HP Compaq dc7100 PC Desktop
How to replace cd drive in hp compaq dc7100?
pls open the case and find the port power and data, you can buy or replace another DVD Rw easily
May 12, 2014 | HP Compaq dc7100 PC Desktop
LOOKING FOR HP COMPAQ DC7100 SPF Ethernet Controller
Go to this website:
HP Compaq dc7100 Minitower Drivers
Select your operating system.
You will then get a list of driver options. You will need to know what network interface you have to select the correct one.
Thanks for using Fixya.
Nov 12, 2010 | Compaq dc7100 Minitower PC Desktop
I'm unable to install the driver for the ethernet controller's driver. please help me
hi
very small problem and solution is easy when the Power supply entered safe mode. take the cmos battery out and then replace dunno if it will work for this.
thanks & regards
Jul 13, 2010 | HP Compaq dc7100 Ultra-slim PC Desktop
CMOS password and Laptop is locked
Power off computer - remove and then reinstall (or replace) cmos battery. This should reset cmos password.
Mar 29, 2010 | HP (350030-001) for Compaq dc7100...
Picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
Mar 12, 2010 | HP (REFURB) HP DC7100 XPP P4 3.2GHZ 80GB...
I have a HP DC7100 CMT,that loses hours during the day.
Hi im Rain.
Ok when installing components inside a motherboard always use a ESD braclet that will ground you to your computer. Failure to use a ESD braclet can fry parts in your system. if you have replaced the cmos battery and it still will not keep yime . The problem may be the motherboard its self. Make sure that you have installed the correct battery for your systems CMOS. If that fails you will need to replace your motherboard.
Jan 13, 2010 | HP Compaq dc7100 PC Desktop
Hi. I need to purchase a DVD burner for my Compaq dc7100 and need to know what brands will fit my computer. Thanks, **** P
I've checked on the specs of dc7100, and it shows that it has multibay optional for 12.7mm removable drives .
I've difficulties finding the exact DVD compatible for dc7100 since it seems that it's already been discontinued.
However, these are the closest match that I've found. Kindly click to double check the specification if it matches your computer:
HP Multibay DVD+RW Drive
HP Slim 8x SATA supermulti LightScribe Drive
Oct 29, 2009 | HP Compaq dc7100 Ultra-slim PC Desktop
HP Compaq dc7100 CMT: Impossible to enter BIOS
Try this,Remove the TPM and start computer,
TPM Card for dc7100
cae4c98.gifOn the desktop and workstation models, the connector is located under the drive bay on the right hand side of the computer. In order to recover the system you should remove the TPM module and re-install the OS.
Please rate this a fixya
Feb 11, 2009 | HP Compaq dc7100 PC Desktop
HP Compaq dc7100 PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
