Question about Rug Doctor Mighty Pro Mpc2c Carpet Cleaning Machine
Brushes not agitating and not cleaning rug. just sprays solution
The Rug Doctor stopped spraying.
did you run out of water ???
Sep 30, 2015 | Vacuums
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Shark navigator vacuum
IF it is belt driven brushes, replace the belt. If not then the motor is most likely bad.
Aug 25, 2013 | Vacuums
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to clean sebo rug brush
there's a button lock on the top of the nozzle and the bottom of the vacuum where they meet. That should release the carpet nozzle from the vacuum cleaner easily.. you may have to jiggle it to get it loose, but there's a button lock mechanism that holds it in place
Apr 13, 2010 | Sebo 9803AM Upright Vacuum
On a Royal #CE6600 it will not spray water on rug,
spray opening may need cleaning (small wire may work)
Aug 31, 2009 | Vacuums
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Suction
No suction, but agitator was spinning and free of debris. Filters were clean. Finally disconnected both ends of the hose and discovered a giant fiber ball clog, the result of a new area rug shedding. Pushed it free with a broom handle.
Mar 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Rug Doctor Mighty Pro Mpc2c Carpet Cleaning Machine Logo
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
