Question about Ovens
On / off foot switch on meile cat & dog 6000 cylinder cleaner will not switch off. How do you remove foot switch cover to see cause of the fault.
I mistakenly sprayed oven with cleaner just before self cleaning , now it's got a stain which I can't remove. Any answers.
and it probably wont be between the high heat and the chemical s you either bleached out or removed the protective covering / causing your stain
Jun 13, 2017 | Ovens
Why are meile door seals so expensive, been quoted 97 pounds
because you bought a Miele, did you think that when you bought it for all those hundreds of pounds that they would use cheap parts, if you wanted cheap parts then why didnt you buy a cheap oven, i'm sorry but there is no logic to your question
Sep 16, 2014 | Ovens
The circulation fan is slow and sticking.
Grease and dirt builds up around the insides of the slots on the fan cover and this may cause the fan to run slowly as it hits it when it rotates. The cover is held on by four self tapping screws in each corner of the cover. Undo the screws, remove the cover and take a look. In my case, the inside of the cover had masses of grease running down it. Despite what it says, I found the paste-on oven cleaner from Lakeland ideal in removing all the grease. It takes a number of goes, but it does eventually come clean. The fan I think is aluminuim and the cleaner reacts badily with it, so don't attempt to clean the fan with it.
When you put the cover back on, you will find the screw holes offset to ensure it goes back the right way up and not upside down.
Feb 08, 2011 | Stoves 720EF Electric Double Oven
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
Kenmore self cleaning ceramic top electric stove flashing f1 and beeping constantly
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven read is reading F1 and beeping. Can;t reset it
$%^&YG
Dec 23, 2009 | GE JKP27 Electric Double Oven
F3 mag curr this causes the oven to run for 6 seconds then stop so when we need to heat any item for say 20 seconds we need to do this 3 times.
Stop using your oven right now. You can cause the repair to be very expencive by using it in this condition. If you are familiar with electrical testers i can help you through the problem. If not just unplug the oven for 1 hour to discharge the high voltage caps which carry 5000 volts. then take the top cover off and the right cover. The compartment will be dirty and dusty. clean this out with a vacum carefully. look at the top of the oven you will see 2 high voltage transformers. inspect them for burn marks. These are one of the causes for an f3 fault if they look excessivly burned up replace the bad one. Turbochef sells those for around $150 also test the fuse there is 3 of them on the bottom right of the cavity. the one on the right is a 20 amp fuse is usually blows for all f3 faults. good luck again if you have a clamp on amp meter let me know we can narrow the fault down more. good luck keep me informed Sean
Nov 16, 2009 | TurboChef TORNADO Electric Oven
The self-cleaning mode will not stop on my Kenmore oven
Aug 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Double Oven F1 Error
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
Can't use my Meile pyrolitic oven fault 90
I turned it off at the main power source and then turned it on again and it worked just fine ... no further problem. I would have been mad if I had called a serviceman and had him lust throw a switch and charge the earth !
May 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Ovens Logo
15 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
