Microwave Model WMH32L 19AS Steam cooking - Washing Machines
The fan on the one day old Oster Microwave runs after finished cooking. All cardboard has been removed.
It is supposed to run on and will stop on its own as long as the door is closed. The purpose is to remove steam and condensation, plus smells from the cooking cavity and cool down the magnetron (the part that emits the microwaves).
Nov 23, 2016 | Oster Microwave Ovens
What causes steam in between glass microwave door
Cooking food in there will cause steam as the microwave heats the water content in your food to make it hot. This will mean some escapes and will settle somewhere it can find cooler than the rest of the unit
Oct 07, 2014 | Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Microwave exhaust fan doesn't really exhause any steam out. Model 721.80042700
The fan is for cooling the magnetron, nothing else. Steam remains in the cavity which is why the door should be left open after cooking to allow the steam to evaporate.
May 30, 2017 | Kenmore 30" Microwave Combination...
I have an over-the-range microwave. When cooking on the stove surface, as steam hits the microwave, it will suddenly turn on. Occasionally you can reset, but usually has to be unplugged to make it work...
That will be caused by condensation affecting the controls of the microwave oven. Not a lot can be done about that except cut down on the steam maybe or wait for the temperature to rise slightly avoiding the condenation problem.
Feb 14, 2011 | GE JVM1650 1000 Watts Microwave Oven
New sanyo microwave, steam or smoke coming out when cooking from 1 minute
Steam is OK as it means whatever is in there is boiling furiously, it may need turning off at that point!
Smoke though means it has gone too far. Check the cooking times used and the recommended cooking times on the packet along with the adjustment for the power of your oven.
Jan 13, 2011 | Sanyo Microwave Microwave Oven
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
F5 Sensor Error?
The failure code list says to replace your Electronic Oven Controll. Contact a Frigidaire parts dealer and check the price and availability.
You will need to give them your make and model number.
Buckle up! It may get expensive!
Good Luck!
Feb 27, 2009 | Frigidaire PLMV168 Microwave Oven
GE microwave model jes1456 has sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Aug 23, 2008 | GE Microwave Ovens
Microwave light
my kenmore microwave model # 66222, doesn't let the steam out, its ventilated so I know thats not the problem, smells like its burning then shuts off and doesn't come back on until its cooled off, this happened when cooking a Baked Potato, also when I cook something for over 5 minutes
Aug 13, 2008 | Microwave Ovens
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
