Question about Casio FX82MS Scientific Calculator
My calc is showing M,SD,R and FIX how do i reset to M and D
My Compaq Presario CQ56 has calculator that keeps popping up when I press the arrow keys or the numerical keys. Please help!!
Well what I really wanted to know the most is if it pops up while you\'re not even touching your mouse or keyboard...
If you changed your .exe to .com like I said and it came back, then it\'s normal... ... Just delete the calc.com file. Don\'t worry, calc.exe came back on its own so the calc.com we made is now useless. That\'s why you can now delete calc.com. It\'s also just to reset what was in your old calc.exe, in case it has a keyboard shortcut and other hidden stuff integrated.
Still gotta make sure though... Can you right-click on calc.exe and choose "Properties" to see if there\'s any keyboard shortcut? The field (shortcut key) should be left blank in case there\'s something in there. Or to "None".
IF the calc.exe still pops up while you\'re not doing anything, then it\'s time for some hijackthis.
Get it here:
http://www.download.com/Trend-Micro-Hijack...4-10227353.html
Do a system scan and save a logfile.
After the scan is over, copy all what\'s in the list (notepad), and post it here.
Let\'s take a look at what\'s running.
Sep 11, 2014 | Compaq Presario CQ56-115DX Laptop
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
Hi, I have a hp50g calc. I was wondering how i can install a formula library from a zip file onto my calc. but more importantly I was wondering if this calc has the functionality to calculate NPV(net...
Unzip it. Transfer it to a Secure Digital card, then plug the card in the SD-card slot. Use the File Manager/explorer and move the library to the Memory location you want.
Jul 09, 2011 | HP 50g Graphic Calculator
How can i perform simple functions, multiplication, addition, etc. The display shows RAD and I press say 5 then + 2 and rather than producing 7 it is showing 52?
the easiest way out of this is to remove the battery and this will force a "soft reset" there may also be a small reset button on the back (use a ball point pen to push). you have your calculator set in radian mode, and there should be button on the calc that say other fuctions, just try pusing some buttons, it won't hurt anything anyway
Mar 23, 2011 | Texas Instruments TI-30XA Calculator
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
NEED HELP WITH TI-15 CALC
You can use the calculator with it on the screen; the indicator simply tells you that it's in a fixed-decimal setting. To remove the fixed-decimal setting, press FIX . (decimal point).
Feb 28, 2009 | Texas Instruments TI-15TK Calculator
Dell Calculator Hotkey
Verify if multiple calc works if you launch it from windows, without using the hot-key. if that does not work, its a windows issue - might need a full repair / install. If windows is able to launch it - you can fix the issue by reinstalling any drivers for your kbd.
Nov 06, 2008 | Dell 0Y3740 Keyboard
Please help
You must have dropped the calc at some point huh? Sounds like the LCD is broken. You can try resetting the MEM, but I doubt it'll work since these calcs don't have color displays and yours is showing a blue line. This leads me to believe that the LCD is broken. Live with it, have it repaired professionaly, or buy a new calc.
Feb 05, 2008 | Texas Instruments TI-84 Plus Silver...
TI-89 Titanium (hardcore reset)?
Hey guys,
Do this it will reset your calc and get you out of your busy state
2nd - left arrow - right arrow - on
It will reset your calc no matter how frozen it is.
Nov 16, 2007 | Texas Instruments TI-89 Calculator
Casio FX82MS Scientific Calculator Logo
16 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
