Question about Canon NP 7130 Black and White Copier
Bands of ink on each copy
Thick bands of ink going down each copy
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The printer makes a thick black line down the back of the copy
can u replace the ink cartridge because this can happen because of leaked ink cartridge
Mar 24, 2010 | Office Equipment & Supplies
How do i stop banding on hp9000 -- i print a job of 25' long first 8' or so print passable - little banding - so i walk away for about 10 mins or so - several feet comes out thick banding lines --ex. my...
The reason for banding on the long panels (especially with solid coverage) is the high content of dissolved air in the ink. Dissolved air causes a gradual nozzle drop-out that cannot be stopped unless you do the head cleaning in the middle of the print. Unfortunately you cannot force HP9000 to do the automatic head cleaning in the middle, it can do it only at the end. Manual head cleaning is possible but it takes such a long time that it shows as stripe on a print, and the productivity suffers. Even the OEM HP ink is full of air inside. Our company did a lot of research in this area and we came up with a special ink packaging technique that ensures the ink is 100% free of air. People who tried printing with our ink can easily print 50-foot panels without any nozzle drop-outs or color shift. If you want more info please call us at 1-905-820-8833, www.solventcartridges.com We also produce portable print head recovery devices and solutions for solvent printer recovery after long periods of inactivity.
Vladimir Digital Sign Technologies www.solventcartridges.com
Feb 26, 2010 | HP DesignJet 9000 InkJet Printer
MAX thickness of wood that this band saw can handle
Generally that's the limit. But to feed a piece that thick, you'd have to have a sharp blade, well adjusted guides and a pretty slow feed rate, depending on the species of wood. I'm guessing the saw will bog down and refuse to cut long before you reach that thickness, unless you have the patience of a saint and don't mind standing there feeding the board through a cm at a time.
Well- tuned it will definitely cut better, but these little portable saws are generally underpowered in my experience..and work best for 3/4" or less thick boards.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 27, 2009 | Black & Decker BDBS100 9-Inch 3.5-Amp Band...
When printing or copying I m getting thick black
First try running maintenance to clean print head on your machine.
If that does not solve your problem replace the ink carts OR Toner cart.
(I am unsure which you have as that was not specified)
Jun 08, 2009 | Brother DCP-8060 Laser Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Motor power question
Horsepower is the maximum power produced by the motor. Saws with high horsepower ratings are good for pattern cutting and cutting down thick stock. Higher horsepower also allows the saw to cut through thick stock without bogging down or burning the wood.
Aug 27, 2008 | Ridgid 14" Band Saw with Stand
Canon NP 7130 Black and White Copier Logo
54 people viewed this question
old marine
old marine
