Question about Amana AEW3530DDS Electric Single Oven
Caloric prestige es0343 manual - Amana AEW3530DDS Electric Single Oven
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
Please help find oven mauel
open oven doors and check behind the bottom of the doors for mod number
Nov 21, 2013 | Ovens
How to turn on self-clean
I have an older model prestige series caloric oven
Oct 01, 2012 | Fisher and Paykel Titan OS301M Electric...
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
How to light the pilot to Caloric Prestige oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 24, 2010 | Ovens
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Need owners manual for Caloric prestige series electric stove. self cleaning instructions
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
My caloric heritage series stove oven will not ignite.. pilot flame is on. I need parts..w here can i get them thanks.
I have a caloric prestige electric stove and the electronic ignition don't work. Does anyone have a solution for this problem?
Oct 05, 2009 | Stoves Ovens
Amana AEW3530DDS Electric Single Oven Logo
23 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
