Question about Acer Aspire 4930-6862 Laptop
I cannot turn on my laptop
even with my battery on
  • 192 Answers
Do you mean that even when you plug it in the wall it will not start? Does it do anything, for instance, does a light flash briefly or do you hear any sound/ Any activity at all? If you do not, it may be that your power cord has a problem, or more importantly, the power supply unit inside of your computer may have failed. Can you give me more information? Thanks.
Posted on Jun 14, 2009
  • 3 Answers
Nobody can answer that question....so just prepare ur money to buy a new one LOL
Posted on Jul 30, 2011
What is the solution in my aspire 4930G?It is no display?
Posted on Jun 24, 2009
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
My laptop does not turn on, i have tried everything even removing the battery for a few minutes.
your battery might be drain. you may try to plug the power cord even without the battery and check if your laptop will open.
Sep 10, 2011 | Computers & Internet
PLSS HELP!!! i have a hp pavilion dv900, and my problem is whenever i use my laptop for just even 2 hours, my laptop suddenly shutsdown or better to say turns off mot likely when i pay rfolympic, a online...
How long have you bought your laptop? If it's still under warranty (specially the battery), bring it back to where you purchase it and tell them the detail. You have problems with your battery that's why you cannot fully charge it and it easily drain. The problem with 3 to 4 times pressing the power button is that when you put your power chord, it will take a moment for the battery to charge an enough power to start your laptop, but I believe nothing is wrong with the switch. It's basically a battery matter. Word of advise, if you have the chance to replace your battery, do not overcharge and do not keep the power chord attached to your laptop most of the time. Allow your battery to reach the lowest level once in a while. This will help you maintain a healthy battery.
Jun 04, 2011 | Computers & Internet
My laptop won't power up even when plugged in. The tech said it needed a new battery, but my experience with my other Toshiba Satellites is that when they are plugged in they will power up. What could...
If it's a battery problem you can remove the battery and connect the AC Adapter for your laptop and you should be able to turn on your laptop without the battery as long as the AC adapter is connected. If it's still not turning on even if there's no battery and the AC adapter is connected that means that the problem is with the components inside your laptop there's no point of buying a new battery for your laptop.
Before doing the steps I mentioned please make sure that there's no other devices connected to your laptop such as printers, usb devices devices etc..
Apr 21, 2011 | Toshiba Satellite P305D-S8900 Notebook
My pc won't start not even in safe mode
you might as well turn off your laptop and remove the batteries and cable into it. And then, press and hold the power button for 8 secs. This will reset your power and operating system settings on your laptop. Then , reinsert the cables and battery into it. Turn on the laptop, and if you still cannot start even in safe mode, consult your PC provider so that they will help you back up the files and repair your laptop....
Mar 06, 2011 | Computers & Internet
Dell laptop D520: When the laptop is plugged into house current (and not on battery power) and the battery is at 100% charge, the battery status light blinks even when the computer is turned off. ...
Sounds a lot like you just have a broken battery. You can get a new one on ebay or laptop battery store. If you've replaced the battery, tried the bios update and it still won't charge i would assume there is an issue with your logic board. If you're out of warranty, somebody has to openthe Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Aug 18, 2010 | Dell Latitude 100L Notebook
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba laptop turns back on when I try to go
The battery seems to be short please remove the battery and use the laptop with the power adapter only to confirm the issue.
Feb 03, 2010 | Computers & Internet
It will not turn on even when plugged into mains
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Sony VAIO VGN-S460 Notebook
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Acer Aspire 4930-6862 Laptop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
