Question about Toshiba G15-AV501 Qosmio Notebook
The hard drive is clicking loudly. It has been doin this for quite some time and my concern is that it is about to crash.
    Problem Solver:
  • 7 Answers
I had this issue, so I removed drive two and it boots up faster again and the noise is gone. I checked the 40GB Drive I removed and it was going bad. What I did was replaced it with another drive, installed XP on it, and now I can boot from either drive but both are seperate OS's.
Cheers
Tim
Posted on Oct 21, 2009
Probably NOT the hard rive. More likely one of the cooling fans has collected a lot of dust and is out of whack. Mine did same. clicking sound especially after 3 -4 minutes after starting. (if it is a hard drive the ckicking will be continuous from mopment of strt up. Also hard drives that click don't last doing it for ANY length of time. If the make that kind of sound they die fast!
Posted on Jun 24, 2009
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Usually the drive that does start to go bad will make a clicking sound or a loud whiring sound espically when it speeds up and slows down, and am fairly sure if you have s.m.a.r.t.s. enabled it will say to backup and replace the hd. if it is not enabled it is in the bios under a tab to enable and disable it. it is called s.m.a.r.t.s. status or hard drive status.(older laptops will most likely not have it) but yes, i would strongly recommend that you see about getting the hd replaced. you could even purchase a used hd from a local computer store or ebay to backup your current hard drive by using norton ghost or any other type of backup program or roxio backup. DARK
Posted on Jun 14, 2009
I have a clicking 500GB Fantom that I can not see in "My Computer" no drive letter exists.
If you drive makes loud clicking sounds it is likely that the drive has experienced a "head crash"
and it is toast.
You van always take it to an expert but they charge a lot of money.
I work on drive all the time and I'd say it is 98% likely that it is toast.
Sorry about that.
Jul 23, 2011 | Fantom Drives G-Force (GF500EU) 500 GB USB...
My Lacie 500GB External Hardrive has just started making loud clicking noises. What should I do? I'm feeling quite worried as this is my only backup system. 3011 10KU SN...
It's not a good sign if a hard disk is making loud clicking noise. It means that the hard drive is about to give up. The clicking sound you can hear is caused by the arm of the hard disk knocking against other components in the hard drive. I recommend to back up your data as soon as possible.
Good luck,
Ryan
May 24, 2011 | LaCie Computers & Internet
My Hard Drive sector is damage due to system crash, it takes a lot of time to format it. I have also tried check disc tool and try to repair damage sector, but the problem was not solved. System can...
It sounds like your hard drive is slowly reaching the end of its life. How long have you had the hard drive? When you say system crash, was the computer accidentally bumped or moved whilst in operation? If this is the case then this can cause quite serious damage to a hard drive and the disks inside would likely be scratched. It sounds like you will have to replace the hard drive. If can purchase a drive and have someone with technical know how install it for you. Good luck. Andrew
Jan 17, 2010 | Computers & Internet
I dropped my external hard drive - a Verbetim terrabyte hard drive. Now, when I turn it on, it makes mechanical noises and won't connect to my computer (USB). I'm not too concerned about trying to fix the...
If your drive is making whining and clicking sounds, then you have a mechanically damaged drive which had what we called a 'head crash' due to the drop!
If you can read/access the disk partitions/drives, I strongly suggest that you perform a full disk backup (with track error skipping) to another device. Also try a file by file copy to another drive (slow but you know exactly what is accessible).
You may want to try to use 'Spinrite' (Google and read about it first) to attempt to repair some of the issues but unfortunately, a disk 'head crash' is usually fatal physical condition and data recovery requires specialized equipment and is VERY expensive!
Hope it helps: let me know ho you go!
Dec 29, 2009 | Verbatim External, USB 2.0, 750GB...
My book western digital harddrive 500 gb
If it is under warranty contact Western Digital normally they carry a 3 year warranty. The HD is bad.
Aug 25, 2009 | Western Digital My Book Home Edition 500...
IBM Travelstar 30gig harddrive refurbished paid 135 for it, clic
Hi
OOUchh! I would say the Hard drive is about to fail, back up data ASAP.
Cheers cbacer
Aug 11, 2009 | IBM TravelStar 10GT 10 GB Hard Drive
Computer will not boot
Does your pc make a different noise than usual when you turn it on? If it sounds like clicking (loud) then your hard drive has crashed. You will need to replace it.
May 28, 2009 | Gateway Profile 4 All In One (MPN...
How can i download themes for xp?
there are several ways to install themes on xp.
1. by installing a third party software which will spice up ur OS big time.But at the same time many have faced issues concerning OS crashes by doin so.
2.Jus download normal xp themes and apply by right click-->themes.
If u wanna try third party softwares go to   http://www.themexp.org/
or else try   http://customize.org/xpthemes
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Crash
sounds like the hard drive took a dump you may need to reformat totally and redo the firmware as if you dont have the ability to do this send back to the manufact and they do this stu ff all the time.
Mar 31, 2006 | Philips GoGear HDD084 MP3 Player
Toshiba G15-AV501 Qosmio Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
