Question about Konica Minolta Bizhub C550
The printer has an unresponsive keypad. - Konica Minolta Bizhub C550
  • Konica Minolta Master
  • 6,680 Answers
Might need to have the control panel replaced but first have tech come and re flash the copier operating system, not the driver which are free Konica Minolta protects its Copier OS via secure web site for dealers and KMBS
Posted on Jan 15, 2016
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
Inner keypad doesn't work
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | LG enV3 VX9200 Cell Phone
My keypad is nonresponsive. I unplugged the unit once, and was able to reset it and it worked for one heating. 2 hours later the keypad is now unresponsive again. Upon unplugging/replugging it again shows...
The membrane keypad has failed.
On some models, you can replace the membrane keypad. I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is only available as part of the whole control panel frame. It's easier, but a little more expensive.
You may choose to do either yourself, or have it done for you.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Let us know here if you need further free help.
Mar 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Keypads will not respond. Either can't turn on or
Possible power supply problem--low voltage from master unit or dead batteries at each switch. Good luck!
Jul 25, 2010 | Lutron Electronic Low-Voltage...
My chefmate 1050 watt microwave beeps nonstop for minutes at a time repeatedly. I must leave it unplugged to get relief. Also, the keypad is unresponsive sometimes.
Either the touchpad or control board is defective. If the ribbon cable was disconnected from the control board and the beeping stops it would confirm the problem. Since the keypad is unresponsive, that probably is the problem.
Jun 21, 2010 | Microwave Ovens
Nokia 6720 Classic occasionally locks up, keypad unresponsive
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etcthey also have a contact page so they may bbe able to help with repairs
Feb 18, 2010 | Nokia 6720 Classic Cell Phone
Keypad is unresponsive and can't turn off
I simply removed the battery cover and disconnected the battery, reconnected and restarted the device. This was the easiest and most obvious way to unfreeze the keypad.
Feb 17, 2010 | Samsung Blackjack SGH-I607 Smartphone
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Dec 17, 2009 | Kenmore Microwave Ovens
V3 unresponsive Keyboard
TRY TO CLEAN THE KEYPAD MEMBRANE OF YOUR UNIT..ASK A TECHNICIAN TO DO IT...THEY USE SPECIAL SOLUTION CLEANING THE KEYPAD & THE MEMBRANE...
Jan 27, 2009 | Motorola Mobility RAZR V3
Samsumg C300
ok... your keypad flex might get loose or dirty keypad contacts inside or check your volume if it get stuck... or
if you can open your phone, checks its connection or keypads contacts get dirty...
hope that solves your prob...
Oct 29, 2007 | Samsung SPH-i500 Handheld
Konica Minolta Bizhub C550 Logo
42 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
