Question about Euro-Pro 7535 Mechanical Sewing Machine
What does the buttonhole attachment look like?
Is it necessary to use the buttonhole attachment or should I be able to use the stitch selection buttonhole function? I have a Singer Advance 7422 model & our Singer store closed no help here.
You don't have to use the buttonhole attachment. Many older machines never had the buttonhole attachment but still made buttonholes. There are manual ways to sew buttonholes on a sewing machine with only a straight stitch and zig-zag stitch.
How to sew buttonhole with an old machine
Jun 20, 2017 | Sewing Machines
What model singer buttonhole attachment will fit a Bernina 807 minimatic machine. This question was asked but I can't find the answer.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this:
https://www.youtube.com/watch?v=JOImaKwv4fU
but you need to purchase a snap-on shank adapter for your Bernina, like this:
http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
Button hole MPG (good tutorial)
807 Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwidgJqA1rDRAhVU7WMKHbfsAfUQFggcMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja (pg 27-28)
Tutorial how to sew buttonholes with the BERNINA presser feet no 3 3A 3B...
Genuine Vintage Bernina Old Style Presser Foot 033 Manual Buttonhole eBay
Jan 07, 2017 | Singer Sewing Machines
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: https://www.manualslib.com/manual/150291/Kenmore-1340.html .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
Huskystar 219 224 type buttonhole
Attach the buttonhole foot. Then pull down the arm to interact with the foot. It is next to the presser bar to the left. Select buttonhole stitch. Start sewing. It should stitch all four sides in one step.
Oct 13, 2013 | Sewing Machines
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
Buttonholes
First be sure to follow the steps described in the manual for attaching the buttonholer.
Second, check that the buttonhole lever is pushed because it returns to it's unpushed state after a buttonhole is completed and therefore it will stitch in the same spot.
Also, try adjusting the stitch length. I've found that I can't make buttonholes while on the satin stich setting ( that little rectangle) but if I move it just a bit towards 1 it will manage to make the right stitches.
Feb 11, 2009 | Brother XL-5700 Mechanical Sewing Machine
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Euro-Pro 7535 Mechanical Sewing Machine Logo
15 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
