My Jeep Cherokee 95 Radiator temperature is always a little above 100 deg. Is this normal ? When turning on the A/C its there, as soon as i drive the jeep or turn off the A/C it comes down a little. Also when parked and A/C turned ON; the jeep starts overheating .. but dont know if around 105-110 is normal temperature or not. Climate here is very hot around 40-43 deg. in the day time.
100 degrees f? That is way too cold Either you have the wrong thermostat or it is wide open. 180 degrees is nominal and give you the best performance.. With AC on, expect 190 to 200 degrees. We are talking farhrnheit and not ccelsius, correct?
Do you have the wondershare dpg converter registration code? can you give it
