Question about Stiebel Eltron Water Heaters
Limit switch I had problems with the limit switch of my Stielbel Eltron heater. I would like to find out where I can find a limit switch.
Tonight I noticed a blue light flashing on the top of my Stiebel Eltron tankless water heater. What does that mean?
Go to the website and find the manual from your heater. In the Troubleshooting section, it tells you what the sequence of the three lights is. This is a similar model.
operation and installation - Stiebel Eltron
https://www.stiebel.com.au/products/downloads/7water supply"). Cold water flows briefly while hot water is being drawn. The air sensor detects air in the water and the ap- pliance's heating output is ..... The flow sensor (DFE) is faulty. Check the flow sensor and replace if required. Flashing green light and steady yellow light. No hot water at flow rate. > 3 l/min. The high limit ...
Downloads Stiebel Eltron
Apr 28, 2018 | Stiebel Eltron Water Heaters
Tempra Plus 29 thermal breakers keep tripping, heater will not heat water. Heater was installed last February and worked fine until a few days ago. I've reset the 3 thermal breakers a couple of times... it...
You can find this site but you can't google the manufacturer site.
If you are not able to resolve a problem please contact us toll free at 800-582-8423 before removing the unit from the wall. Stiebel Eltron is happy to provide technical assistance. In most instances, we can resolve the problem over the phone.
Dec 26, 2017 | Stiebel Eltron Tempra 29 Whole House...
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Hi, I just got my new DHC 10-2 today, the installation was easy but I have a problem. The problem is that heating is not constant. Once I mix the cold and hot water I should have an uniform temperature but...
This electric demand water heaters has one heater element. The flow switch turns it on. The thermostat cycles it on and off according to temperature. There is no medium.
You need to run the sink on hot while you take a shower. This kind of cancels out the savings on electricity.
Or get a higher flow shower head. Your screen on the shower head may be partially fouled.
Here is the brochure. It shows the flow rates for the different models.
http://www.stiebel-eltron-usa.com/sites/default/files/pdf/brochure-dhc.pdf
Dec 14, 2017 | Stiebel Eltron DHC 10-2 Electric Tankless...
The water heater "Stiebel Eltron
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the problems associated with your model.
I believe they offer a refund if the 'fix' doesn't work.
The manual might also have troubleshooting.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, there were same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, the brand-specific-ness of the problems, and the inability of the manufactures to take care of their customers.
If I understand correctly, the manufacturer will refer you to the installer.
There are not many ways a do-it-yourself-er can fix a tankless.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Oct 30, 2010 | Stiebel Eltron DHC 10-2
My heater stoped heating water. the light is out that shows temp.my husband is in Military and i am alone. I checked circut breaker but I don't know if or where there is a circuit breaker at the box or a...
I had the same problem with the Stiebel Eltron Tempura 24. Right side unit worked (with blinking LED), but the display and left side (including LED) did not work.
This is CRITICAL. Do not take the cover off unless you have turned off circuit breakers at the circuit breaker panel AND tested that there is no power. There is a lot of voltage/ampreage here and it could be life threatening if you get shocked. Call an electrician (or a plumber) if you don't know what you are doing.
My problem was solved by resetting the safety thermal cutout switch on top of the non working unit (red single press thermistor). See this manual http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf page 8.
Jan 30, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
Water Heaters Logo
56 people viewed this question
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
