Question about Daewoo DTQ-27S3FC 27" TV
Will not turn on
TV was working fine.  I turned it off, left for half and hour, came back and turned it on.  It made a slight clicking noise inside twice and that was that.  I've unplugged it-let it sit-replugged it in, but nothing.  Is this another land-fill item or could it be fixed?
  • loral Nov 01, 2007
    Thanks, but this sounds too complicated and sounds expensive. thanx for trying!
    Genius:
  • 1,694 Answers
It can be fixed with difficulty----requires power supply overhaul,
HB Electronics kit # 103-088 + additional parts I can describe
if you want to tackle it?...........T.
Posted on Oct 31, 2007
Last night, the freezer door on my older GE Profile fridge got left slightly open. This morning, it was making a loud noise and some of the food inside was starting to thaw. I turned it off for awhile...
The door being left open would have caused frost to form around the evaporator fan motor and that would be the source of your noise.
If the lights are still working then it is probable in defrost, wait about 30-45 min and see if it turns back on. If not then you might have a different problem.
What is the model number for your fridge? The model number is normally in the fridge on the right hand side.
Mar 13, 2013 | Refrigerators
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
TV won't turn on at all. It doesn't click at all to turn on and we checked the power cord, the plug, and the outlet. All seem to be fine. It worked just fine the night before and even if the tube went...
You are correct, the switch would still click even if something major had failed inside the TV. There is a small microswitch inside the TV directly behind the on/off button. The microswitch can break or get stuck and there is usually no way of fixing it without taking the back off the TV. You could try repeatedly pressing the on/off switch rapidly as this can (very) occasionally unstick it, but it's probably broken.
This isn't generally a user replaceable part as the actual switch is soldered to the PCB. I would take it to a TV repair shop, but if you are planning to remove the back of the TV, make sure it's unplugged and don't open it until the power has been off for at least half an hour as you can still get a considerable residual current shock!
Hope this helps.
Regards,
BElectric
Nov 15, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
When my LCD TV has been off for an hour or so upon turning it back on there is a low humming sound and only the sound comes on and then after half an hour or so and turning it off and on 20 times the...
plse dont move when there are working, inside them are components which gets heat, vibration causes separation or desoldering them from board.(dry joints)
it may be coming from cables having dry joints take your set for repair.
Mar 26, 2009 | Televison & Video
Tv. turns off in about half hour
replace U14701-6 and U14701 IC'c
per Ttomson tech suport.
Jan 12, 2009 | Proscan PS50670 50" Rear Projection...
Edsr1600: clicking noise eminating from front right
I had the same problem. Left the unit on overnight, next morning the unit was working fine. Also if you turn the unit off and back on it can take up to a hour for the system to reboot.
Jan 02, 2009 | EverFocus EDSR1600 16 CHANNEL 160GB...
RCA HDTV Powering Issue
Could anything have spilled inside? Since you weren't home you can't be sure. unplug set, get a handheld hairdryer and blow thru the tv side vents for a half hour on medium. Move the dryer around all vent locations. Plug tv back in when done and let me know.
Sep 13, 2008 | Televison & Video
For my logitech z-4 speakers, my right speaker works fine but my left speaker has stopped making noise. if you turn it up to maximum you can slightly hear it, but its really quiet. can i fix it?
googled the same exact prob. and found this forum. after reading through the postings to get some ideas, I went back to my speaker set and unplugged the serial port that hooks up to the remote. blew on the connector and plugged it back in and VIOLA! I got sound from the left speaker again! Must be my awesome, smelly breathe that woke up the left speaker....
May 31, 2008 | Audio Players & Recorders
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Chirping noise
Sounds like something may be shorted out inside keeping the power supply loaded enough it wont start, dont recommend trying to fix unless you know EXACTLY what you are doing, there are some high voltages inside, I wold Call a TV tech out to repair, Just FYI, these sets from Phillips/MAG usually have CRT fluid getting cloudy causing discoloration/fog to pix around this age and older, between both repairs, some sets start around $1000, just an idea.
Jul 16, 2007 | Philips 60PP9352 60" Rear Projection...
Daewoo DTQ-27S3FC 27" TV Logo
44 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
