Question about Hoover Platinum LiNX Cordless Stick Vacuum
The lithium batery drains almost immediately. Fully charges. I bought a new battery, but same thing. Any ideas?
The lithium battery charges but drains almost immediately. I bought a new battery, but same thing. Any ideas?
Bissell bolt IONXRT. Vacuum fully charged, runs for about 10 seconds and then shuts off.
Vacuums of that type are prone to failure of the lithium battery but the charger also could be at fault.
Feb 12, 2017 | Bissell Vacuums
Can I leave the battery charger plugged in my Dyson dc 44 animal after it is fully charged?
Hi, I have a Dyson DC56 with a lithium battery for about 18 months and I leave it plugged into it's charger when not in use. I do notice the Dyson charger seems to switch off automatically when charged. I don't have any problems so far. It you have a Genuine Dyson Lithium battery and the genuine Dyson charger it should not be a problem. That is because Lithium batteries have very precise requirements for their charging cycles and therefore the correctly designed charger required to make them work safely is a somewhat intelligent design and needs to be of good quality in having to meet those requirements. So use the original Dyson Charger. Also most high current Lithium Batteries will also have a protection circuit built in further increasing safety and reliability. Just don't use cheap cloned Chinese made Lithium chargers, because you will never know if they have been designed or even will operate correctly.
Now if you have old technology Ni Cad (Nickel Cadmium), LA (Lead acid) or NiMH batteries with basic cheap chargers they should not really be left connected to a charger full time.
Dec 07, 2016 | Dyson Vacuums
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
The power cord was not working, so I ordered a new one. The roomba was then coming off the charger and blinking red. Now when I charge the roomba it does this half start and chiming noise in the video
I don't have one of those but I'd guess if the charger was bad the batteries might be bad from being charged incorrectly. I would try to charge and discharge a few times and see if things improve. If they are lithium batteries that probably won't help and only chance is to replace the battery pack.
Sep 29, 2012 | Vacuums
Just put a new battery in scuba and it runs about 30 seconds (completely charged)
1) replace again the batteries by new ones and completely charged.
2) test the charger if if functioning properly, can be faulty, and not charge well the batteries.
3) test the power supplies inside from the scuba, to due some short circuit drain the batteries.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Hoover Platinum LiNX Cordless Stick Vacuum Logo
71 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
