Question about Radio Communications
I have a cobra 1000Gtl cb base station was talking one night next turned on and no receive or transmit is the audio chip bad whats that chance or where else should i look trired four mics mics are good radio powetd up no tx rx
  • 24 Answers
Make sure your PA switch is in the off position
Posted on Apr 27, 2014
2 Suggested Answers
  • 27 Answers
SOURCE: Cobra 148 gtl Low / No receive audio
No audio out / low audio out....This is a constant problem with the COBRA 148 gtl....to get a good level of volume replace the
electro caps ...start around the two speaker wires and work back from there. I'm in the process of rebuilding a 148 gtl and have found caps that are leaky and dried out...after replacing nine the volume went up to a good level...now i need to fix the distortion
and background hash. Did you know that there are many posts
on FIXYA about this same problem I.E. great TX , great PA but poor , or no audio out. these sets have been made in sevetal countries...The sets made in Taiwan or China have poor quality
front panel pots (the carbon track is micro thin and simply wares through to the material the track is printed on) This has the same effect as removing a wire from a pot I.E. no audio. The good news is that 99% of parts in the radio are freely available and that includes the front panel controls. ONE WONDERS IF THE SET IS WORTH THE EFFORT !!!
CHEERS GUYS / GIRLS.
Posted on Jul 03, 2008
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Radio comes on will not talk or recieve
Is the meter moving on key up or another radio transmiting to it?
Switch for S/RF, CAL, SWR.........set to S/RFRF gain knob full clockwiseSquelch counter clockwise
If just audio is missing my be Audio Chip i think IC3Bad Crystal or solder to it.May be bad PLL chip any of these 3 could affect both TX and RXI do not suspect mic as there would still be audio just at low volume on receive.
Oct 03, 2011 | Cobra 29 LTD CB Radio
My radio just recently incurred this problem. It receives WX band, uses PA correctly (mic transmits over PA). It will not receive or broadcast over any standard CB channel (1-40). The needle is just...
Hi, do you have the switch in CB mode ? Might be the audio chip, or the Finals, you will need a tech to do the job so he can set the ma on the finals. Hope this was helpful....My name is John. Thanks....good luck...
Aug 28, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 25 LTD classic no transmit or receive.I have checked the mic and finals and they check ok. I beleive it might be somewhere in the VCO.Any help
With the radio on, and the case off. Rub your finger gently across the contacts of the audio chip on the trace side of the board. If you hear noise from the speaker it is good. if you don't hear anything(make sure the speaker is hooked up) then the audio chip is bad. You need to change it.
Jan 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
No audio transmit or recieve adio chip 1A7217AP IC
it may not be that IC but maybe a electritic cap or a transister.
Jul 30, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
Jan 08, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
