Question about Manitowoc MAN-KF2 Koolaire Freezer Reach In Two Section Self Contained 6in Legs
Manitowoc koolaire refrigerator part list kf2
Manitowoc Koolaire KR-2S Specifications
These specs are as close as I could find
May 20, 2014 | Refrigerators
Water constantantly flows from condenser outlet
What you need to do is find the hose coming from the bottom of the freezer and place it into the dain pan. With the water flow going into the drain pan the compresser discharge line should evaporate the water during normal operation.
Sep 07, 2012 | Manitowoc MAN-KF6E Koolaire Undercounter...
Cleaned machine now stuck in harvest and dump valve will not close
There is a little finger that the door needs to hit to get it back to the freeze mode...You don't have the door in the correct position...
heatman101
Aug 26, 2010 | Manitowoc Koolaire Undercounter Freezer...
Manitowoc series 100 makes ice but wil not go into harvest. the ice just keeps building up. need a service manual and advice to walk me thru thi problem.
I'm not sure what you mean by a series 100. Manitowoc series are by the model number first letter. B-series, Q-series, J-series, etc. A 100 lb Q-series would be the most recent. If memory serves they started with A, C, E, G, B, J, S, and are now on Q. You can get most of the service books on their website here.
http://www.manitowocice.com/?xhtml=xhtml/mii/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
Sorry I cant be of more help without a complete model number.
May 14, 2010 | Manitowoc Koolaire Undercounter Freezer...
What is the life of the Manitowoc 76-2306-3 water pump?
Mine just went out. It lasted since June 29, 2006. So about 4+ years. Ya know just around after the warranty runs out.
Jan 01, 2010 | Manitowoc Koolaire Undercounter Freezer...
Ice machine takes a long time to make ice.
Clean the coil out with compressed air. Clean the evaporator with ice machine cleaner.
Dec 08, 2009 | Manitowoc Koolaire Undercounter Freezer...
Harvest light on Manitowoc Q series stays on
obtain wiring diagram
sounds like the switch that initiates the harvest is stuck closed....sounds funny but i would try to tap the unit and see if the light goes out
Oct 01, 2009 | Manitowoc Koolaire Undercounter Freezer...
Freezer not keeping food frozen and their is ice on the liquid line filter.
This is one of two things, either the inline filter on the machine has gone bad. Or there is a leak and it is low on freon. If it is low on freon a company can come out and put in a saddle tap and check both freon levels and also add some dye for leak check.
May 26, 2009 | Manitowoc MAN-KF2 Koolaire Freezer Reach...
How Do I maintenance a manitowoc series 150 ice machine
find the filter remove clean with water, coils should be shiney. This should fix the problem
Apr 23, 2009 | Manitowoc MAN-KF6E Koolaire Undercounter...
Manitowoc MAN-KF2 Koolaire Freezer Reach In Two Section Self Contained 6in Legs Logo
67 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
