Gemsound dvd 800 manual - Audio Players & Recorders
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
Gemsound xp-550
A diode/rectifer or voltage stabliser, or leaky capacitor in the power supply.
Also the main transistors in the power amp or if it has an output IC - that!
If you can in anyway disconnect the power supply section from the amp circuit, you can isolate which part is faulty. For if it blows when disconnected from the power amp, you know it's just the power supply that's gone. And if it does not blow - then it's the amp!
Aug 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
GemSound XP-550, worked great for about 2 hours
The outputs are probably blown. This should be under warranty. Return it for a replacement.
Dan
Jun 29, 2009 | Audio Players & Recorders
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Manual
Contact Gemsound thru their email.
Sep 04, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gemsound power speaker
have no idea but what kinda speaker is it for a car or a house if for a car then u might have hooked it up wrong or the coil is blown hopes this helps
Apr 06, 2008 | Gem Sound Gemsound Concert Series...
47 people viewed this question
 Grubhead
Grubhead
