Question about Others TE968H 5.8G 5 Inch 8 Channels Wireless Mini DVR Monitor Suppo... ToyRC
Other frequency band
Bought a TE968H 5.8G 5inch dvr monitor with the wrong 8 channels. Transceiver is working on 8 a different channels. Can I switch somehow the 8 channels in the monitor to another band?? how?
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
How to set the swr on a superstar 3900
do you have an owners manual.It tells you how to do it in there. The 6 bands a,b,c,d,e,f are the radios band frequencies.If you put your on c you will have cb channels.
May 11, 2014 | Radio Communications
No sound floureon dvr
have floureon 8 channel dvr but cannot get the sound to work or the motion detection buzzer to work. it is not my wiring or cameras or microphone as all worked with the previous dvr correctly. have bought another microphone, camera and dvr compatable and linked it straight to monitor and it works. plug into floureon dvr/no sound. my previous cameras and dvr gave motion detection buzzer no probs, but no buzzer from floureon box/help
Jan 30, 2014 | TOA Electronics TOA NX100S Network Audio...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
It says "frequency out of range" on the screen
Had the same thing happen with a Night Owl 8 cam system. I set the resolution too high (1900x1200 I think) and it said Frequency Out of Range on my monitor. I could not find a solution so I finally disconnected the dvr and took it to a large lcd hd tv. I connect through the vga cable and it worked. I reduced the resolution back down to something I know would work on my monitor and all is good.
Oct 17, 2010 | Night Owl Optics Night Owl LION4500...
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
Others TE968H 5.8G 5 Inch 8 Channels Wireless Mini DVR Monitor Suppo... ToyRC Logo
80 people viewed this question
Top Others Games Experts
Lesley Cameron
Lesley Cameron
Pamela Leach
Pamela Leach
Are you an Others Game Expert? Answer questions, earn points and help others
